Kinked fuel line
New User
Re: Kinked fuel line (D.specs)
if the fule line is just a rubber hose, then just go to the parts shop and get you a piece of hose that is the same diameter and cut it longer so that it loops into the filter, then it wont kink
Re: Kinked fuel line (vntperformance)
Its not the rubber hose part hes talking about im sure. Let me guess, you were doing an H22A swap and you have a JDM fuel rail right?
You are going to have to follow it back to wear there is a joint, and buy a new piece. You could try and straighten it out, but the metal pipe will be much weaker, and could possibly break.
Buy a new line, and try and bend it in small increments, and not all in one spot.
New User
Re: Kinked fuel line (GZR4DR)
Thanks for the support, I'm going to buy a fuel gauge and connect a piece of fuel line hose as my connecter and flange the ends so it won't slip off...........Scary, but I have faith And no I don't have a JDM fuel rail.
But what type of fuel regulator should I get? And whats the price?
hannslebo
06-05-2009 06:13 AM
