idle problem
Old Apr 29, 2002 | 06:50 PM
...me0w's Avatar
Default idle problem
i have a 93 prelude with a jdm h22a motor swap conversion but i still have not figured out how to get the car to idle a 750 rpms as i should i have checked for vacuum leaks and exhaust leaks. hears the catch though if you unplug the sensor directly behind the intake manifold and the temp sensor directly underneath the distributor the car will idle but at 1750 rpms. if anyone has any advise i would greatly appreciate it.
Old Apr 29, 2002 | 06:55 PM
ItzTw's Avatar
Default Re: idle problem (93jlude)
Check the cap and rotor
Old Apr 29, 2002 | 11:45 PM
garagespecial
Guest
Posts: n/a
Default Re: idle problem (ItzTw)
check your trottle cable (sometimes it gets stuck)
adjust your trottle screw (on the tb)
does your idle stay at 1750? or jump?
Old May 1, 2002 | 07:22 AM
bb1turbovtec's Avatar
You just have to check every vacume line. it took me about 2 1/2 months to find my leak... if not, try the idle screw on the TB. good luck!
goldgreen90ef
Jul 9, 2009 07:13 PM
crxsiperf
Aug 13, 2006 09:17 PM
rice a roni
Apr 15, 2005 09:49 AM
OneFastGsr
Oct 8, 2003 08:30 AM
