check engine light
Old Oct 21, 2006 | 05:15 PM
dohmahklan714's Avatar
Default check engine light
i just did a swap from turbo to stock and my check engine light came on. i tried taking out the ecu and battery to reset the car but the light still remains. i even did the paperclip trick to find out the code and it turned out to be a long flash on the cell light which means 10 code ait. then i took it to arco, they did a diagnostic but it nothing came up. does that mean there's nothing wrong with my car? how do i reset or find the problem if there isn't any?
Old Oct 21, 2006 | 08:43 PM
SmogKing's Avatar
Default Re: check engine light (dohmahklan714)
Check if all your plugs are hooked up, if you have a disconnected plud sometimes it will set a solid CEL.
Corruption
Jun 3, 2006 12:08 PM
Project_EK
Aug 13, 2005 04:08 PM
laurat
Oct 14, 2002 12:54 PM
VTECVillain
Jan 6, 2002 11:40 AM
sackdz
Jun 23, 2001 09:36 AM
