Honda sounds like a subaru
Old 08-13-2012, 03:10 PM
niterider96cord's Avatar
Default Honda sounds like a subaru
Original post:
https://honda-tech.com/forums/showth...6#post47728436
I need some more people that might know whats going on. Maybe that have experienced it before.
Sorry admins your gona kill me when you find this.
Old 08-13-2012, 03:20 PM
derp resistant
kelsodeez's Avatar
Default Re: Honda sounds like a subaru
sounds like a cylinder isnt firing. do a compression test on all 4 cylinders, check voltage to each spark plug, check spark plugs.
Old 08-13-2012, 03:58 PM
gzes's Avatar
U no u coukda bumped ur old thread right.... Lol
Old 08-13-2012, 04:10 PM
It didnt need bumped the prelude guys just arent much help.
Old 08-13-2012, 04:12 PM
Anon51's Avatar
are you sure your firing order is right? pull each spark plug wire when its running and see if the rpms lower or rise in all four cylinders. i'd also get someone with a computer and chrome pro to check what the sensors on the motor is telling the ecu.
Old 08-13-2012, 08:22 PM
nitro911's Avatar
May be a dumb suggestion but mine sounded like "subaru" at one time and it was because the spark plug wires weren't in the proper spots. So did you check to make sure your wires are going to the correct spots on both areas?
Old 08-14-2012, 05:08 PM
Ya the firing order is right, it doesn't run rough necessarily like if the firing order was off, it feels like its either has a slight misfire or maybe map isn't reading air flow at times? So its getting too much fuel. I don't really know how to explain it, I'm going to make sure everything is tdc this weekend and test map probably.
702SI
12-05-2014 03:59 PM
Civic Hybrid
10
08-17-2008 09:35 AM
HypnotikEFX
05-02-2005 09:11 PM
LShatchie
11-17-2004 02:55 PM
TruePlayaz114
03-21-2003 12:53 PM
Quick Reply: Honda sounds like a subaru
