CEL 08. TDC sensor??? WTF. please help.
I recently had my car into the shop and my distributer, rotor, cap, everything were replaced. He said he checked my timing and everything. Now. 2 weeks later. I have a CEL 08. And its the TDC sensor in the Distributer. I dont know what to do. My car is running like crap. Should i not drive on it?? It also feels as if i have no vtec. could the plugs just have gotten fixed?
Re: CEL 08. TDC sensor??? WTF. please help. (stehigs321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stehigs321 »</TD></TR><TR><TD CLASS="quote">I recently had my car into the shop and my distributer, rotor, cap, everything were replaced. He said he checked my timing and everything. Now. 2 weeks later. I have a CEL 08. And its the TDC sensor in the Distributer. I dont know what to do. My car is running like crap. Should i not drive on it?? It also feels as if i have no vtec. could the plugs just have gotten fixed?</TD></TR></TABLE>
could be a defective distributor. I've had a brand new distributor from honda go bad on me before. I would suggest to you to tell the mechanic to replace the distributor for another new one. also the TDC sensor is inside the distributor.
Re: CEL 08. TDC sensor??? WTF. please help. (B18C5-EH2)
It is a 96 civic with a 98 B18c1 in it. running an OBD2 ecu. could resetting the ecu help. I mean i just had it replaced. shopuld i take it off and reinstall it. or just give my mechanic a call?
I dont think resetting it would help since you been driving for like 2 weeks and no problem. Your distributor should have warrenty so give that machanic a call and see what he thinks.
Re: CEL 08. TDC sensor??? WTF. please help. (MikeNice)
The only way to replace the TDC sensor (or the CKP/CYL) is to replace the distributor housing. Aftermarket dizzy's seem to have a higher failure rate than an OEM piece - FYI.
What could also be happening is that the bushing inside the dizzy has become worn to the point where its allowing the shaft to 'vibrate', which in turn cause variations of the TDC output signal (I believe its the TDC sensor that is most effected by a worn bushing).
Take off the distributor cap....notice any brown/red dust accumulating?
Re: CEL 08. TDC sensor??? WTF. please help. (Disco_Stu)
i took off the cap. Looks fine in there. Anything else i should take off to check the insides. Should i take off the entire distributor and look at it?? The thing is i dont have a timing light. So ill make sure to mark it. What exactly am i looking for again??
Pooping on children
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Disco_Stu »</TD></TR><TR><TD CLASS="quote">did you really need 2 posts? wtf?</TD></TR></TABLE>
did u really need to make that worthless post???fucktard...............anyway i would take it back and have the mechanic replace the dizzy.
Re: CEL 08. TDC sensor??? WTF. please help. (BADEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BADEG6 »</TD></TR><TR><TD CLASS="quote">
did u really need to make that worthless post???fucktard...............anyway i would take it back and have the mechanic replace the dizzy.</TD></TR></TABLE>
yes i did; don't get all butt hurt b/c you didn't get to make it first.
I was referring to this post https://honda-tech.com/zerothread?id=802232 which is the same damn thing. arshole
Anyway. should i take it all the way off and look for something. What should i look for. Is the stock timing on the distributor side right in the middle?? i dont have a timing light so should i just put the distributor in the middle somewhere when i put it back on?? Again what should i be looking for with my TDC sensor problem.
jus2sho
10-09-2006 10:22 AM
.Kevin.
09-12-2005 12:51 PM
