getting in depth with TIMING....
Old Dec 10, 2004 | 10:18 AM
h22a193's Avatar
Default getting in depth with TIMING....
ok I have my head off now, doing some "things" ,when putting evrything back together, I have to put the T- belt back on the cam gears and make sure its set...
What is the best way to make sure everything is lined up perfect?
When I did my timing belt change, I had the crank pulley off, and lined that line up under the cover. Is there any way to get around taking the pulley , and cover off, and still being dead on accurate?
I was thinking putting a dowl stick in the #1 cylender, then turning to I see the mark on the flywheel, and set it where the upper most part of the stick is....
Because if I was right, that little mark on the flywheel is pretty broad, meaning It could be off a deegree or 2?
what do you think?
Old Dec 10, 2004 | 10:38 AM
LudeyKrus's Avatar
There is no need for all that. If you set it according to the manual, then you have nothing to worry about.
Old Dec 10, 2004 | 11:09 AM
v4lu3s's Avatar
RTFM
i never used hte flywheel marks, i use the ones on the oil pump and cams liek the helm manual recommends, then i use a thin screw driver to lock the cams in place through the holes in the cams and cam plates....
Old Dec 11, 2004 | 11:43 AM
h22a193's Avatar
the manual says to line the flywheel up to tdc mark and set cams, when putting back on the head. Just making sure I done have to take the pulley back off
Old Dec 11, 2004 | 12:12 PM
rocketlude's Avatar
The timing can only be off by 1 or more teeth. 2 degrees isn't enough to change anything. Once the teeth in the belt and the gears in the pulley line up your either off a tooth or your in time. 1 tooth is about 15 degrees.
Old Dec 11, 2004 | 12:21 PM
SKDRCR's Avatar
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">then i use a thin screw driver to lock the cams in place through the holes in the cams and cam plates....</TD></TR></TABLE>
you mean teh balance shafts.
I left my upper tb cover off to double check all the marks
after evrything was assembled.
make sure you jump the service connector
when setting the timing with the dist.
Old Dec 11, 2004 | 12:29 PM
Hawkze_2.3's Avatar
Default Re: (SKDRCR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">
No, my H23 has holes in the cam caps to lock the cams.
Old Dec 12, 2004 | 06:54 AM
h22a193's Avatar
ok so do I or dont I need to take the lower cover and pulley off?
Old Dec 12, 2004 | 07:12 AM
thehondaguru's Avatar
Default Re: (h22a193)
in order to do it the right way yes you do
Old Dec 12, 2004 | 10:21 AM
SKDRCR's Avatar
Default Re: (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">
No, my H23 has holes in the cam caps to lock the cams.</TD></TR></TABLE>
I know they do, but it doesn't say anything about locking
the cams while changing your timing belt in the Helms though
piotrush
Nov 20, 2006 04:13 AM
PreludePhill
Jun 12, 2006 04:20 AM
KL14
Nov 7, 2005 09:11 AM
JiGGaPiNNo
Oct 16, 2005 05:34 PM
preluda92
Oct 24, 2003 09:41 AM
