fuel pressure problem HELP!
Old Jan 26, 2003 | 04:16 PM
Familycarfromhell's Avatar
Default fuel pressure problem HELP!
i took of my turbo on my h22 accord, i did not take out my fuel pump for the reasons of dropping my tank. (takes too long to do) i'm putting the turbo back on in a few weeks. now my problem is my fuel pressure is a 50psi. when i lean out the regulator the lowest it goes is 50 psi? why cant i drop my pressure. i tried other
pressure regulators and they did the same thing. the reason i cant lower my pressure is because of the pump? or no.
burning rich as ****. what can i do?
thanks
Ryan
[Modified by Familycarfromhell, 1:17 AM 1/27/2003]
Old Jan 27, 2003 | 05:09 PM
Default Re: fuel pressure problem HELP! (Familycarfromhell)
all right? thanks for the help.......................well...see ya later!
Old Jan 27, 2003 | 05:12 PM
Firedrake's Avatar
What kind of regulator are you using? It's possible that the pump is pushing enough fuel that you're maxing out your fuel return regardless of your regulator.....if it's a stock honda regulator, you can drill a little hole as described on http://www.theoldone.com or if it's an AEM you need to put in a larger dump jet....I'm using the middle sized one on mine and it works fine with my 255lph hp pump.....
Brian
Old Jan 27, 2003 | 07:33 PM
Default Re: fuel pressure problem HELP! (Firedrake)
holy **** man! thats what i'm talking about? THANKS!!!!
Ryan,
Old Jan 27, 2003 | 07:54 PM
Firedrake's Avatar
No problemo
Brian
jman86
Nov 7, 2024 12:19 PM
yywjsutherla
Honda CR-V & Element
Sep 13, 2017 12:38 PM
ek9turbo
Feb 24, 2004 03:46 PM
djnikko
Dec 7, 2003 10:42 AM
