Engine Sputtering and O2 sensor question- h22
Old Oct 16, 2004 | 01:02 PM
eric416's Avatar
Default Engine Sputtering and O2 sensor question- h22
lately my car has been running like crap. if i step on the gas hard below 2000 rpm the car fall on its face and goes nowhere and the engine sputters. after it goes above 2000 rpm it runs fine. A while ago i got CEL 1 which i think is the O2 sensor but i never did anything about it because it went away. Could this problem be caused by a bad O2 sensor because its not getting the right air/fuel mixture?
Old Oct 17, 2004 | 03:17 PM
eric416's Avatar
Default Re: Engine Sputtering and O2 sensor question- h22 (eric416)
anyone??
Old Oct 17, 2004 | 05:12 PM
esca's Avatar
try resetting the ecu..
if that doesnt work.. might wanna invest in a new o2
Old Oct 17, 2004 | 06:15 PM
dan4h22a's Avatar
Default Re: Engine Sputtering and O2 sensor question- h22 (esca)
bump
Old Oct 17, 2004 | 08:42 PM
eric416's Avatar
Default Re: Engine Sputtering and O2 sensor question- h22 (dan4h22a)
i did reset the ecu but it still runs like crap. no code in a while tho
Old Oct 17, 2004 | 09:24 PM
kb7709's Avatar
Not to hijack your thread, but I've had a similar problem. Getting the O2 sensor and Fuel Delivery System codes. Changed the O2, but it didn't help and I'm still getting both codes. Since then I've changed the fuel filter, cleaned the EGR valve, swapped the throttle body with another one to get a different TPS in the mix. Nothing has helped. Mine sputters up to 3200 RPM's then smooths out. It runs ok when cold until the CEL comes on. I can shut the engine off and restart (now it's warmed up) and it'll run ok again until the CEL comes on again.
Can anyone help us with this???????? Please??????
Modified by kb7709 at 6:16 AM 10/18/2004
Old Oct 18, 2004 | 12:07 PM
eric416's Avatar
Default Re: Engine Sputtering and O2 sensor question- h22 (kb7709)
kb, do u get a CEL everytime u drive the car?
Old Oct 18, 2004 | 12:12 PM
98TypeSH's Avatar
Have you guys checked your timing ?? I had the same problem, but my damn car was running rich. Pulling the vac i capped off solved that problem right quick,
Check your timing first, Check your plugs. You may be running rich and in the process of fouling plugs.
Old Oct 19, 2004 | 05:52 PM
dan4h22a's Avatar
Default Re: Engine Sputtering and O2 sensor question- h22 (98TypeSH)
what exactly is the VAC and where is it located it sounds like a problem i have...just bought the damn car H22a
skiracer8148
Apr 25, 2007 05:41 AM
EGCivicCoupe
Apr 5, 2005 07:36 PM
Achenar
Apr 18, 2004 02:06 AM
5 Skware
Sep 12, 2003 07:05 PM
MOD5CSi
Aug 6, 2001 08:54 PM
