ECU question... answer needed quickly yo!
Old Sep 19, 2001 | 09:19 AM
JG Luder's Avatar
Default ECU question... answer needed quickly yo!
OK... the GSR ECU will plug and play into a Lude... but will a obd1 B16 ECU do the same?
Old Sep 19, 2001 | 12:32 PM
JG Luder's Avatar
Default Re: ECU question... answer needed quickly yo! (JG Luder)
"Bueller......................... Bueller............................... Ferris Bueller........................................... ...."
Old Sep 19, 2001 | 01:20 PM
aklucsarits's Avatar
New User
I don't know for sure, but one problem you will have is that the b16's have no secondary intake runner like the Prelude and GS-R have. So since the b16 ECU cannot control it, the secondary intake runners will be either always closed or always open - I'm not sure which... But neither one is good for drivability... If they are stuck closed, you have no top end. If they are stuck open [EDIT ] you will have no bottom end and I don't know if it would even be able to idle...
On a side note, have you actually used the stock GS-R ECU on an H22a? I looked into this ECU swap into my OBD2 Prelude a while back, and I was told by more than one person that it would not even idle with a GS-R ECU.
Andrew
[Modified by aklucsarits, 6:07 PM 9/19/2001]
Old Sep 19, 2001 | 01:31 PM
JG Luder's Avatar
Default Re: ECU question... answer needed quickly yo! (aklucsarits)
https://honda-tech.com/zerothread?id=65607
the obdI GSR ECU will work... at least with my 4th gen. and I don't care about HOW it drives, just so long as it DOES drive for 3 days.
Old Sep 19, 2001 | 02:49 PM
New User
Sorry, this is kinda taking this thread OT but...
Don't you think something is really fishy looking about that dyno plot... The H22a motors hit peak power right at 6800-6900 rpm. If you look at those plots, they are peaking at only 6600rpm for the GSR ecu and only 6300 rpm for the H22a ECU - and falling off hard after that... On top of that, that h22a ecu plot is definitely not a motor with just "a milled head, all the bolt on's, stock cams, stock intake manifold, S pistons", and a fuel regulator. If there is no VTEC controller in there, then where is the legendary H22a VTEC spike? Surely a fuel pressure regulator alone cannot even out a huge spike like this bone stock H22a4 plot:
I mean come on, that plot from Import Review with the H22a ECU is making 160hp+ before 5000 rpm! That's like a gain of 40-50 HP over stock at that RPM point! - There's just no way... I call BS... I really don't think those are even H22a plots. I think there is either a lot more going on that car than just the listed mods, or those plots are phoney...
Andrew
Old Sep 19, 2001 | 02:57 PM
JG Luder's Avatar
man, I'm not arguing dyno plots, cause I wasn't there. You may be 100% correct here...
BUT!
My point is that it will work!
Thanks for the warning about the secondaries.
I think I may have a line on a GSR ECU for the weekend.
Old Sep 19, 2001 | 03:04 PM
New User
Ha Ha! OK... I digress...
You know the GS-R ECU would probably not be a good long-term idea for your car either. The 1993-96 Prelude VTECs use peak and hold injectors. The GS-R has always used saturated type injectors. The 97+ Preludes also use saturated injectors - and that's why I was looking for info on using the GS-R ECU on a 97+ H22a4...
The two types of injectors use different voltage signals in Hondas. So you could risk damaging the ECU and/or your injectors by using a saturated injector GS-R ECU with your peak and hold H22a injectors...
Andrew
Old Sep 19, 2001 | 03:06 PM
JG Luder's Avatar
only for a weekend baby!!!!!!!!!!!!!! My ECU should be back by Tuesday. Then I have my 9k redline back AND some upgraded fuel curves. yummy.
ken'd
Jul 8, 2006 05:01 PM
silintegra
Aug 12, 2005 05:49 PM
TKL
Apr 28, 2004 08:53 AM
red96
Jul 12, 2002 05:24 AM
