Easiest way to remove h22 IM nuts?
Old 11-14-2013, 09:58 PM
97accordbuildlx's Avatar
Default Easiest way to remove h22 IM nuts?
wanting to remove the intake manifold from the head (head removal).
4 nuts on the top of the manifold...whats the best way to get to those?
i dont want to disassemble more than i have to.
what in your experience worked best
thanks in advance
Old 11-14-2013, 10:09 PM
holmesnmanny's Avatar
Default Re: Easiest way to remove h22 IM nuts?
It's not the top 4 that you need to worry about. It's the bottom 5. You can only get to them with a box wrench and it's going to be tight under there. No real special method. Just tedious.
Old 11-15-2013, 12:46 PM
oh if memory serves me right the bottom ones (along with the support bracket) were a B but the top ones you can even get to without removing something or other, like the fuel rail
Old 11-16-2013, 06:52 AM
motoxxxman's Avatar
12mm box wrench. make sure you use the closed end. and if you need more leverage, slip the closed end of a 13 or 14mm box wrench over the open end of the 12mm wrench
Old 11-19-2013, 12:17 AM
lol this is what I already said...i guess you thought I was saying the opposite
Old 11-19-2013, 05:31 AM
something gnarly
5SpdH22's Avatar
i just used a ratchet and a 6" extension. i've taken it off 3 times that way.
might have to do with not having that vacuum box or a charcoal canister or any of that stuff back there.
Old 11-21-2013, 12:01 PM
acedude180's Avatar
There is a wrench made by snap on that u can turn every nut from the top. I crack the bottom nuts first . Hand loosen them. Then remove the easy top ones last if u do it opposite the manifold weight goes on the bottom buts and makes it more difficult to hand loosen. Tighten in an inside out pattern
D.j. Holley
01-26-2018 09:49 AM
dseriesboulder
03-24-2014 01:31 PM
B_Swapped93
12-06-2013 06:30 PM
leon phelps
06-21-2013 09:43 AM
vinuneuro
10-08-2007 06:39 PM
Quick Reply: Easiest way to remove h22 IM nuts?
