compression test and ignition module help needed pls.
2.2 1994 vtec prelude..
HI, I did a compression test today on my car and then when i put all the spark plugs back and went to switch my engine on it turning over but not starting up?
My road repair man told me that my ignition module has gone and that is common witih hondas. he said that it had nothing to do with the compression test but my car was running fine until then? has anyone had this problem or know any fixes?
are you getting any spark, and fuel? When I do a compression test, I usually unplug my injector resistor box and take off my coil wire. maybe you did something similar and forgot to put it back on?
hi,
thats the problem i didnt do wither of them?
i dont know were the coil wire is or the injection fuel box? if you could tell me that would be a great help..
but as i didnt do this what could of happened? could this of caused this problem?
thanks
thanks
