Compression test???
Old Sep 11, 2002 | 01:55 PM
prelude1897's Avatar
Default Compression test???
How would I go about checking my compression on my motor? I did a motor swap in my 97 Prelude, cause I hydrolocked my last one, and I just wanna make sure I'm running the right compression with this new motor. To me, this motor doesn't seem to be running like it should....Also, how can I tell if my timing is right?
Thanks
Old Sep 11, 2002 | 02:09 PM
714's Avatar
714
Default Re: Compression test??? (prelude1897)
Compression tester screws into you spark plug port, has a gauge on it. Timing light hooks up to your spark plug wire, flases on you pulleys so you can see the marks.
Old Sep 11, 2002 | 02:16 PM
so what kind of numbers should I have???
Thanks
Old Sep 11, 2002 | 03:06 PM
H23 Power's Avatar
around 200-210 i would think
Old Sep 12, 2002 | 07:01 AM
GAperformance's Avatar
New User
Default Re: Compression test??? (F23 Power)
Mine has 210 in all 4. The testers aren't 100% accurate so they very. The one from sears is usually higher than the one from NAPA. Typical numbers are anywhere from 180 to 220.
Old Sep 12, 2002 | 09:17 AM
Default Re: Compression test??? (bkw97lude)
Thanks alot guys...I'm going to use my friends tester whenever I get a chance
Old Sep 15, 2002 | 07:47 AM
TimoneX's Avatar
New User
Pull your injector fuse prior to testing, and test compression at WOT. Otherwise you'll get low numbers and will have a stress attack.
Old Sep 15, 2002 | 09:39 AM
heiyu's Avatar
Default Re: Compression test??? (TimoneX)
i was wondering if you need to pull all the spark plugs or just one at a time when doing a compression check
RyanWhite
12
May 31, 2015 09:36 AM
one bad dx
Jan 4, 2007 09:55 AM
danny98r
May 18, 2005 12:31 PM
zracer240
Apr 24, 2005 08:35 AM
smslude
Feb 25, 2003 10:40 AM
