code 9: CYP
Old Dec 3, 2002 | 05:49 AM
DarkJedi's Avatar
Default code 9: CYP
my car is throwing a CEL code 9, CYP sensor, checked the wiring and it turned out fine. i tried swapping out the cyp sensor from my SOHC distributor and its still didnt fix the problem, but when i use my SOHC ECU the light goes away, what could be the problem? i hope its not a bad ECU. will a USDM ecu work on a JDM h22a?
Old Dec 3, 2002 | 06:21 AM
3gLudeH22A's Avatar
Default Re: code 9: CYP (DarkJedi)
Im having the same problem...it comes on every once in a while..it just started doin it too!!! Along with that my EGR CEL is comin on every so often too...im fed up with this crap.
Old Dec 3, 2002 | 06:54 AM
laughinxxx's Avatar
New User
Default Re: code 9: CYP (3gLudeH22A)
I had a code 10 b/c of a bad connection to the ECU. Make sure that you have the harness in there and that there isn't any debri around the connection.
Old Dec 8, 2002 | 03:15 PM
123thecreiscalledbdp's Avatar
guess what guys? You have a bad ecu, if you check the ohms on the distributer plug 4 and 8 and the ohms are from 350 to 700 ohms that means your distributer is fine cyp is fine it is your ECU, i have same problem and changed eu and all is fine check to see if you wiring harness is fine............ 1
Old Dec 8, 2002 | 03:51 PM
DarkJedi's Avatar
Default Re: code 9: CYP (123thecreiscalledbdp)
yea its a bad ECU, just figured this one out, i tried my friends USDM ecu yesterday..
hugot231
Jul 7, 2010 02:32 PM
new_climber
Sep 17, 2009 08:26 AM
MelloYelloCRX
Jul 22, 2006 05:17 PM
SlipAngleX
Jul 14, 2003 05:11 PM
