Check Engine Light?!?
this is the one i got: http://www.exhaustproslinc.com/carunconwita.html
i got the one with the 2.25 inlet/outlet... i also got it with no air/o2 bungs... it's going to need to be modified by a muffler shop... it's going to need to be cut, flanges added and an o2 bung added... i'll keep you updated, i should be doing it within a month. good luck.
-colin
-colin
The only O2 sim that works with honda OBDII ECU is the following:
http://www.lakeeffectperformance.com...ns&product=428
The do it your self ones and the others you might find will NOT work. If the simulator does not use RPM and TP sensors as inputs then it will NOT work, and you will still get a CEL.
Also you may or may not need an O2 sim with a high flow cat. Some of the high flow cats flow a little too well, and you can still get a CEL every few days/weeks.
[Modified by 57STS, 11:41 AM 3/19/2003]
[Modified by 57STS, 11:43 AM 3/19/2003]
I went on there website and i didnt see anything for a 2001 prelude! I saw that they had it for 96-00! Will that still work eventhough have a 2001?
97+ prelude are all the same. So yes it will work for you. I don't think OBD1 uses a 2nd o2 sensor like the obd2 have. So there is no need for the O2 sim on older cars. If you want to make sure look for a O2 sensor AFTER your cat, if you don't see one then you will not get a CEL from using a strait pipe (no cat).
I have heard that even with the random tech cat you can sometimes still get the CEL to come on
So its not 100% that the CEL will not come on, eventhough i am buying a Random Tech cat.
So is there anything out there that will work instead if buying a stock cat from Honda? Does everyone actually have the stock cat on there car's? What do some of you guys have on your car?
p.s. Thanks for all your help fella's, i really do appreciate it
So is there anything out there that will work instead if buying a stock cat from Honda? Does everyone actually have the stock cat on there car's? What do some of you guys have on your car? p.s. Thanks for all your help fella's, i really do appreciate it
Nitto
Aug 10, 2004 07:11 PM
