Cat Problem
Old May 18, 2003 | 12:24 PM
JaiDieM's Avatar
Default Cat Problem
I dont know if this is normal but after I drive my car and get home and turn off the engine....the cat is kind of giving off some smoke near the header part...I dont know if my car is just cooling down or is there something wrong with my cat??
Old May 18, 2003 | 12:39 PM
Behan's Avatar
Default Re: Cat Problem (LuDeAcrOus29)
this could be a million things, did you check for a leak? how much smoke is coming off? need more specifics
Old May 18, 2003 | 12:52 PM
PrecisionH23a's Avatar
you might be leaking oil, have you changed your filter out recently?
Old May 18, 2003 | 01:38 PM
JaiDieM's Avatar
Default Re: Cat Problem (GudeH23a)
just got my oil changed recently and there isnt a lot of smoke but enough to get me worried....so it might be my oil filter??
Old May 18, 2003 | 01:54 PM
prelude1897's Avatar
Make sure your filter is on tight enough. You may just have a little bit of oil still on the downpiping or whatever its called. Each time I changed my oil, some would drip onto the piping causing it to smoke after I shut off my car.
callmechad
Aug 11, 2009 07:18 PM
poupey
Sep 1, 2005 03:08 PM
oemDC2
Mar 22, 2004 10:03 PM
lenn
Mar 8, 2004 04:04 PM
Mindtrap
Aug 7, 2003 01:30 PM
