Best H22a valves
Old 12-09-2002, 10:36 AM
satan_srv's Avatar
Default Best H22a valves
Alright let's get some opinions on valves.
What brand and why. I'd also rather not spend more than I need to. I'm N/A (abotu 220-240whp) for now, so I'm thinking my criteria is:
1. Lighter valves
2. Provides better intake velocity
Is that all I should be thinking of? I already have titanium retainers, dual springs and crower stage 3 cams
[Modified by satan_srv, 2:37 PM 12/9/2002]
Old 12-09-2002, 10:52 AM
JG Luder's Avatar
Default Re: Best H22a valves (satan_srv)
First thing I would do is talk to John at KMS. You'll be glad you did. I've seen that man's shop and all his equipment... he can do some serious stuff.
When I chose who to build MY motor for the Gumball, he's the first, and only, person I called.
He did a Prelude for a good friend of mine... it was the only other 13 second, full interior, N/A on street tires Prelude in the Southeast that we know of. And it was mild in comparison to mine.
click the link in the sig, or call 1-770-652-3538
Also, headwork is PARAMOUNT. He can do that too, and he has the flowbench to give you flowcharts if you want them.
Old 12-09-2002, 11:09 AM
rjr162's Avatar
To be honest, alot of the pro guys still use Stock valves. Spoon even recommends it themselves (that's what they use in their cars). Factory vavles will bend, not brake, as most aftermarket will do if something goes wrong. Just something to think about
Old 12-09-2002, 11:12 AM
satan_srv's Avatar
Default Re: Best H22a valves (JG Luder)
Originally the head was ported and polished and I believe the IM was paort matched as well to the crower head, just using stock valves. I will talk to my engine builder tomorrow and see if they flow benched it the first time.
Old 12-09-2002, 11:13 AM
satan_srv's Avatar
Default Re: Best H22a valves (rjr162)
That's funny, that's what we did in the first place. Well if no one can make a great case for aftermarket valves that's exactly what I was planning to do...right now I have some stock bent valves, which is not a bad thing if it saves my pistons/saleeves
Old 12-09-2002, 12:57 PM
Flh22chic's Avatar
Ferrera valves are good! Skunk 2 suck!
Old 12-09-2002, 06:14 PM
New User
nighttime's Avatar
So when is KMS starting the work? Id like to see some pics of it, because Im considering them when I get around to getting some headwork done.
Old 12-09-2002, 07:25 PM
New User
Allstar's Avatar
Default Re: Best H22a valves (nighttime)
You should talk to Dan from DPR. He's built two 2.2's of mine both with upgraded valves, no complaints at all, I can't say enough about him. He's knows his ish and has been building motors since we where in dipeys.
Flow bench this and flow bench that, its all about torque.
dpr-racing.com
Old 12-09-2002, 08:21 PM
mugenbb6's Avatar
Default Re: Best H22a valves (Allstar)
How about crower valves?
Old 12-09-2002, 09:12 PM
H22pwrd's Avatar
http://www.alaniztechnologies.com/bhseriesparts.html
I imagine the same applies to H22 valves. This is from the guy who builds heads for the quickest all motor Honda on the planet by the way.
Old 12-09-2002, 09:22 PM
rjr162's Avatar
Default Re: Best H22a valves (H22pwrd)
one thing you have to remember.. honda makes valves that are suppose to last for a long while. Sure they aren't really designed for high HP applications, but if something goes wrong, the valve bends to protect the engine. After all, honda put a buttload of R&D $'s into them
Aftermarket valves are more for high HP applications, where stripping down, checking, and rebuilding the engine(s) is don'e routenly. So after a few runs, you check everything out... notice something odd, replace it. Of course if you miss a problem, instead of bending the valves tend to snap, really messing tons of stuff up...
Just info for more thinking!
Old 12-10-2002, 12:50 AM
fastludeh22's Avatar
Default Re: Best H22a valves (Flh22chic)
so why does skunk 2 suck? any reason to back this up or you just dont like them? ive heard good things about them. the thing i liked is that they have a high compression version, which bumps up compression .3 points.
i however went w/full ferria .5mm oversized valvetrain. what kind of valve job are you going to get?
Old 12-10-2002, 06:29 AM
Flh22chic's Avatar
Default Re: Best H22a valves (fastludeh22)
I guess you haven't seen my other posts, I'll just explain it again.
When I got my swap I got the Skunk 2 Stage 2 cams, valves, springs, and retainers too. 2 weeks later my exhaust cam broke. Down for 2 weeks. One week later, my hydraulic tensioner broke, along with one of my springs, and all of my valves were mushrooming. The Skunk 2 valves are very loud, and don't seem reliable. This not only happened to me, but another friend of mine who has the same set-up. I switched to ferrera valves, and I'm ahppy. He spent another $2000 trying to get everything working at Honda. I would go with the best, and ferrera is the best, so I've heard even before I got them!
Old 12-10-2002, 08:27 AM
boomslang's Avatar
Blah, blah, blah. Talky, talky, too much talky.
Unless you are using some form of forced induction, keep your stock valves. They work very well. Stainless exhaust valves are a good idea for FI motors. The best aftermarket valves only flow around 2-3% better than stock anyway.
Old 12-10-2002, 02:30 PM
damn, that sucks. glad i went w/the best to begin with. i was just wondering if it was worth the extra money, but now i know it was. ill be putting my engine back in really soon.
did you replace you auto tenisor w/the manuel one? what part of fl you from?
Old 12-10-2002, 03:45 PM
Quaalude's Avatar
Default Re: Best H22a valves (boomslang)
Old 12-10-2002, 05:10 PM
Ritteri's Avatar
Default Re: Best H22a valves (Quaalude)
First off when using a Skunk2 stage 2 cam your supposed to swap out the hydralic tensioner for the H23 mechanical tensioner. As it cannot handle the stress from the upgraded valve train. This is well know to play havoc on valves and camshafts. I also am a big fan of the stock valves. I was looking into the Skunk valves, but most hardened valves dont bend, they just shatter/break off clean. Which can be a bad and expensive thing.
Old 12-10-2002, 06:24 PM
HotWheelz's Avatar
Default Re: Best H22a valves (Ritteri)
anybody have any complaints about Ferrea vavles, how's the flow on them, my valvetrain is "crower stage 3 drag n/a cams, with crower dual vavle springs and crower Titanium retainers, also have h23 tensioner assembly, with a ported head... new valve job, but wondering if it be a good idea for ferrea instead of the stock valves, looking for lighter tougher valves,,, no nos or turbo straight na... looking for valve that flow and won't break... idea's.. and how much are Ferrea valves (stainless steel ones) can you get them in a high compression design... cause i want 12.0 and I have a worked chamber (rounded factory flaws) and lost .5cc in each chamber .. fully polished... so i need higher compression valves, can't mill head because i have stage 3's... ideas ?
Old 12-10-2002, 07:38 PM
Ritteri's Avatar
Default Re: Best H22a valves (HotWheelz-turboh22dx)
Skunk2 does make a high compression valve(the valve is falt on the bottom instead of indented)that would probably work out good. They raise compression about .4-.6 . They would probably do the trick.
Old 12-10-2002, 07:58 PM
the compression raise is .3 in a h22. ferreia does not mak a high compression one, that i know of
Old 12-10-2002, 10:26 PM
satan_srv's Avatar
thanks for the input.
I'm sticking with stock valves.
hingi
06-12-2007 10:01 PM
ebp 99 si
05-05-2003 03:07 PM
HotWheelz
01-27-2003 05:42 AM
HotWheelz
01-22-2003 09:26 PM
chameleon
03-11-2002 05:06 AM
Quick Reply: Best H22a valves
