Anyone know where this connect to?
Old 10-09-2011, 04:39 PM
JusAccord's Avatar
Default Anyone know where this connect to?
im under the car, connecting all the wires together, this one righ here i cant figure out, i might be missing something but does anyone know where this connect to? its black and blue inside
Old 10-10-2011, 04:59 PM
AWDManiac's Avatar
Default Re: Anyone know where this connect to?
looks like the knock sensor plug. Not a 100% but its right above the oil filter where the h22a4's are.
Old 10-10-2011, 11:12 PM
Froidas's Avatar
It can't be knock sensor, because it's connector has only 1 wire.
Did you check service manual? There are all pinouts with wire colors in several pages somewhere... If you find, you can get connector number and then find the explanation in engine bay picture. I hope you understand, what I mean I am used to 4gen manual, but 5gen should be very similar + many engine connectors are all the same in H22 motors.
Old 10-11-2011, 04:54 AM
I live under a rock
spoolinlude's Avatar
Kinda looks like O2, can't really tell.
Old 10-11-2011, 05:55 AM
Honda owns me
typemismatch's Avatar
Knock sensor should be a single wire, that does look more like the O2 sensor wire, and that's where it should be on a H22 harness, off the back of the block.
I've never used an H22 harness on an H22, I converted a B-series and an F-series in my cars.
Old 10-11-2011, 05:58 AM
Froidas's Avatar
It can't be O2 (lambda, yes?) too, because he would definitely notice that and it's 4 wires.
Old 10-11-2011, 06:17 AM
I live under a rock
Is the harness for that car/engine? May be something you don't need/don't have...
Old 10-11-2011, 09:32 AM
JusAccord's Avatar
i was thinkin the 02 sensor too but all of them connected already, this h22a4 was pulled out of a civic but when i pulled out my h22a4 out my car there was a wire attach to the engine on the bottom by like the water pump, i wonder if thats where it goes and if i need it, im still in the porcess of gettin this engine started up
Old 10-11-2011, 11:16 AM
Honda owns me
H22A4 harness would have 2 O2 sensors being that it is OBD2
Old 10-11-2011, 11:24 AM
aznfreakyguy's Avatar
that looks like top view with the intake manifold off, could be the iab plug
Old 10-11-2011, 12:17 PM
JusAccord's Avatar
yea u right its only 2 O2 sensors so it cant be that, its something else tho, im about to go look for someone out here wit the same car i have and look under LoL
Old 10-11-2011, 12:19 PM
JusAccord's Avatar
iab plug?
Old 10-11-2011, 01:35 PM
Honda owns me
intake air bypass, part of the secondary runners in the H22A intake manifold
Old 10-11-2011, 03:38 PM
JusAccord's Avatar
o ok ill check it out
Old 10-12-2011, 01:55 AM
pentaq's Avatar
What are the wires colors?
Old 10-12-2011, 05:32 PM
JusAccord's Avatar
its black on the outside and blue in the inside
Old 10-12-2011, 05:37 PM
JusAccord's Avatar
i dont have a service manual for this car
Old 10-12-2011, 09:46 PM
nus_dogg's Avatar
I believe that would be your CKP wire.
Old 10-15-2011, 02:24 PM
JusAccord's Avatar
wha CKP stand for?
Old 12-07-2011, 11:47 PM
razorlude's Avatar
1 wire?....exhaust temperature sensor.
Old 12-08-2011, 11:38 AM
97ludedude's Avatar
the wire that hooks up to iab solenoid on the bottom of the intake manifold should be a two wire connector. if that is a one wire connector it is the knock sensor. your oil pressure switch is right in that area too but your oil pressure light would stay on if it was it.
UNKNOWN_MEMBER
06-27-2005 02:27 AM
ZaxEG
10-02-2003 07:35 PM
cccya
04-09-2002 08:12 AM
92 CiViC gsR
04-08-2002 10:30 PM
Quick Reply: Anyone know where this connect to?
