can i use a stock VX wire harness in a h22 swaP?
i have a 92 vx.....and iam puttin a h22 in there..the motor is a 95..but all it comes with is the engine...tranny and ecU...can i use the vx harness since its a v teC?
Re: can i use a stock VX wire harness in a h22 swaP? (92 CiViC gsR)
i beleive so, i think only the vx model has that capability, i have an issue of sport compact car that says all about it, ill check it for you when i go home
craig
craig
Yes but you will have to add wires for the EGR valve, knock sensor and add a couple wires to the 02 sensor since the h22 is a four wire 02 sensor and the civic is 2 wire.
Re: can i use a stock VX wire harness in a h22 swaP? (HatchEG6)
whats the egr valve and the knock sensoR? and i can care less about the o2 sensoR....never had them in my car..dont want them..
The egr valve is the exhaust gas recirculation and the knock sensor detects any knocking in the motor when vtec engages. If you dont care much about a check engine light then you dont have to add the wires for the o2 and the computer wont work properly not knowing how much air is at the cat and header.
tnsxsear1
08-20-2004 09:48 PM
