Antenna Problem.
Old Oct 17, 2003 | 06:48 PM
Lude-Conduct's Avatar
0861 OORAH!!!
Default Antenna Problem.
The antenna on my Prelude doesn't go down. You can hear the motor turning, but it doesn't catch. Is this a job for a mechanic, or is there a DIY option?
Old Oct 17, 2003 | 07:41 PM
0861 OORAH!!!
Anyone?
Old Oct 17, 2003 | 08:02 PM
lude_si_95's Avatar
Default Re: (Lude-Conduct)
mine does the same.....and im wondering the same
Old Oct 17, 2003 | 08:03 PM
93ludeSi's Avatar
the antenna mast has a plastic strip on the end of it with teeth that lock with the gear on the motor to pull it up and down, the teeth wear out and the gear slips instead of pulling the antenna down, you can replace the mast yourself with a few tools and a little patience
Old Oct 17, 2003 | 09:06 PM
0861 OORAH!!!
Default Re: (93ludeSi)
How though, u know a guide anywhere?
Old Oct 17, 2003 | 09:26 PM
gaber's Avatar
same problem. I just got sick of the noise of the antenna motor going and no antenna moving so i disconnected my antnenna and pushed it as far down as i could.haha problem solved(kinda)
Old Oct 17, 2003 | 10:13 PM
93ludeSi's Avatar
Default Re: (fresh_rides)
i wish i could scan the pages out of the manual i have, it isn't a bad job, just hard to explain, you have to take the chrome nut of that is visible from the outside of the car and then pull the mast and strip out , then simply thread the new one in
Old Oct 18, 2003 | 10:45 AM
0861 OORAH!!!
Well, I figured that much, I just cant see a way to take the chrome thing off.
Old Oct 18, 2003 | 10:46 AM
0861 OORAH!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ludeSi &raquo;</TD></TR><TR><TD CLASS="quote">i wish i could scan the pages out of the manual i have, it isn't a bad job, just hard to explain, you have to take the chrome nut of that is visible from the outside of the car and then pull the mast and strip out , then simply thread the new one in</TD></TR></TABLE>
Also, where would I get a new one of whatever you're talking about ? lol
Old Oct 18, 2003 | 11:43 AM
93ludeSi's Avatar
the replacement mast is a dealer item, so head to honda for that, they also sell a tool to remove the nut, or you can take it off with some pliers, just be careful not to scratch it all up
Old Oct 18, 2003 | 01:36 PM
0861 OORAH!!!
Thanks man, i'll wrap my pliers in electrical tape. You mean a Honda dealer right?
Old Oct 18, 2003 | 03:08 PM
93ludeSi's Avatar
sent ya a p/m
Old Oct 19, 2003 | 10:22 AM
92lSilude's Avatar
so just take the nut off... pull the mast and strip out.. and then put thread the knew mast in and last put the chrome nut back on
ndrew2505@yahoo.com
Oct 27, 2008 01:35 PM
teg_dc2
Dec 10, 2007 11:39 AM
pfork
Jun 21, 2007 06:28 PM
smikeL
Nov 23, 2004 05:21 PM
SleepinGSR
Feb 27, 2002 02:03 PM
