antenna problem
Old Nov 23, 2004 | 01:30 PM
smikeL's Avatar
Default antenna problem
hi there. my antenna is stuck up like a tampon. does anyone know how i make it go back down?
Old Nov 23, 2004 | 01:56 PM
ian.'s Avatar
Default Re: antenna problem (mikeL619)
if the motor still work and the antenna is still up then u need a new track inside or the antenna is bended and if the motor dont work get a new one
i cut mine but i dont listen to the radio
Old Nov 23, 2004 | 01:58 PM
B18OnTop's Avatar
Default Re: antenna problem (IC33)
you can go with an S2000 antenna with no motor.
Old Nov 23, 2004 | 03:16 PM
gsr-2nr's Avatar
Default Re: antenna problem (B18OnTop)
if ur antenna is stuck up u need a new mast that is if the motor still works
Old Nov 23, 2004 | 05:21 PM
deejaycherub's Avatar
http://www.team-integra.net/fo...97368
lude2go
Oct 17, 2005 04:32 PM
debogsr
Jun 3, 2004 10:30 AM
beaterman
Aug 20, 2003 05:50 PM
distuRbed
May 16, 2002 08:45 AM
