hondata problem
Old Aug 11, 2002 | 11:57 AM
servion's Avatar
Default hondata problem
I installed the hondata (2bd) on my OBDI p72, and it isn't working. The p72 was apready chipped, and worked fine before the hondata install. I replaced the 2 chips (they were both already socketed, and I put them in oriented right). I soldered in the 4-pin connector, and there was already 2 capacitors wired in. The j1 was already jumped too. I put it in the car, and the light flashes once and then stays on. It idles like crap and doesn't run right. Once it warms up, it won't idle--- it just dies. I installed 550cc injectors before all of this as well. I installed the old p13 prelude ecu, and it behaves the exact same way as the hondata ecu. The only difference: when I hit the gas quickly, throttle response is immediate with the prelude ecu and takes about 1/2 second with the hondata ecu. I figure its running rich with the 550cc's. Because it runs the same way with both ecu's, my initial guess was that the hondata is not working? Any help (its sunday and hondata isn't open)
Also, datalogging wont work. I click connect, and it just sits there saying 'connecting'
Old Aug 11, 2002 | 12:02 PM
turboex's Avatar
Default Re: hondata problem (servion)
your hondata chip is bad. thats all there is to it im sure. mine was the same i had a chip burn from the wrong ecu and it did the same thing. who did you get the hondata through?
[Modified by turboex, 9:03 PM 8/11/2002]
turbodcxbro
Engine Management and Tuning
Jan 9, 2010 11:31 AM
THEUSED
Apr 1, 2006 04:08 PM
CA18DORI
Dec 23, 2005 05:19 PM
speedyonez
Oct 20, 2003 06:49 PM
