HOW do you retard timing
Old Mar 18, 2005 | 12:49 PM
turbo-d's Avatar
Default HOW do you retard timing
i was just wondering how can i retard my timing by like 2 degrees on my turbo 99 civic ex.this has prolly been answered but i cant find it.thanks
Old Mar 18, 2005 | 01:03 PM
Pullig's Avatar
Default Re: HOW do you retard timing (turbo-d)
u turn your distributor clockwise toward the front of the car to retard and turn toward the firewall to advance
Old Mar 18, 2005 | 02:35 PM
btotherizzle's Avatar
don't forget to jump the service connector or the computer will correct your adjustments.
Old Mar 18, 2005 | 03:09 PM
xenocron's Avatar
Default Re: (btotherizzle)
Are you talking about retarding your base timing or retarding your timing under boost?
Old Mar 18, 2005 | 04:31 PM
turbo-d's Avatar
Default Re: (xenocron)
uner boost,and what does he mean by rotate the distrbutor cap.thanks
Old Mar 18, 2005 | 05:25 PM
leed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by btotherizzle &raquo;</TD></TR><TR><TD CLASS="quote">don't forget to jump the service connector or the computer will correct your adjustments.</TD></TR></TABLE>
The ECU is completely oblivious to where you've set the base timing. Your moving the physical sensor pickups by rotating the distributor.
Old Mar 18, 2005 | 07:32 PM
Pullig's Avatar
Default Re: (leed)
ok look at ur dizzy it has 3 bolts 12 mm i think loosen all 3 but dont pull the bolts jsut loosen and make sure before u loosen the bolts to make a line so u know where stock setting is and then jsut turn the dizzy. im not really sure how much of a turn =degrees u would need a timing light for that .
Old Mar 18, 2005 | 08:03 PM
xenocron's Avatar
Default Re: (turbo-d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo-d &raquo;</TD></TR><TR><TD CLASS="quote">uner boost,and what does he mean by rotate the distrbutor cap.thanks</TD></TR></TABLE>
You need an external unit...most popular I have seen is the MSD BTM...it senses boost pressure and retards your timing based on how much boost it sees.
The other (and better) method is to go with a Chipped ECU / Standalone...you can setup the Boost Retard directly in the ignition maps which means now need for an external unit or retarding the base timing at the distributor.
Old Mar 18, 2005 | 08:52 PM
Tad's Avatar
Tad
you could also use the jackson racing btc
don't know which is better, the msd or jr unit, but they'll both do the job.
best would be to have it properly tuned though.
R.A.T.
Sep 26, 2007 01:41 PM
allnaturalb16
21
Aug 14, 2007 08:57 PM
miksew
Jun 7, 2006 08:03 AM
brusk13
Jan 11, 2006 07:01 PM
Daniel
Aug 22, 2003 07:05 PM
