Wierd Problem when Checking CEL
Old Aug 21, 2005 | 08:58 AM
Corporation's Avatar
Economic Upturn, WUT
From: Alittle Placed Called None of Your Damn Business.
Default Wierd Problem when Checking CEL
I plug my wire into each slot on the blue plug, when i turn ignition on. The maintenance light blinks(always does) abs blinks, and so does my check engine light.
Why is the ABS blinking, and why is the REQD MAINT blinking all the time when I turn ignition?
Old Aug 21, 2005 | 10:23 AM
B18C_DD's Avatar
Default Re: Wierd Problem when Checking CEL (ahrpr)
Not sure what your syaing. Is your ABS blinking constantly or is it when you turn the car on then it goes out?
Same with the Maint Light. Does it flash once or does it blink for a minute or two and then go out?
If you can clear that up i can help you.
Old Aug 21, 2005 | 02:06 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: Wierd Problem when Checking CEL (B18CDD)
How long has the Maint Req. light been flashing like that when you turn on the car? It's normal for it to do that before it stays on solid. I believe it stays on for a couple hundred miles, then it becomes solid.
If your ABS light is blinking, then your ABS system is also throwing a code. You check it the same way as the Check Engine light.
Old Aug 21, 2005 | 05:18 PM
Default Re: Wierd Problem when Checking CEL (shamoo)
Well I justgot the car for cheap 4 days ago or so. My REQD MAINT light blinks for a min or 2 and my blinks for a min or 2 just like the check engine, the abs and check engine blink only when im using the blue plug, the reqd maint does it all the time when I turn on the ignition, sorry for late reply.
Old Aug 21, 2005 | 05:32 PM
shamoo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ahrpr &raquo;</TD></TR><TR><TD CLASS="quote">Well I justgot the car for cheap 4 days ago or so. My REQD MAINT light blinks for a min or 2 and my blinks for a min or 2 just like the check engine, the abs and check engine blink only when im using the blue plug, the reqd maint does it all the time when I turn on the ignition, sorry for late reply.</TD></TR></TABLE>
Okay, only 4 days. Like I said, the Maint Req. light will blink for a while. After a few hundred miles, it will come on solid when you turn on the car. It's just a notification to get service done, it doesn't mean anything is wrong with the car. It is set to go off automatically every set number of miles (about 3750 or so).
There is a button under the dash of the driver's side that lets you reset it.
Okay, so did you check the codes? Do you know how to check for them? There is a sticky on the top of this forum showing you how to do it, and how to read the codes.
Old Aug 21, 2005 | 05:46 PM
EDIT
Im only throwing code 41, primary oxygen sensor heater, i checked it and the pins are puled out of the plug, is there a way to put the pins back, or do I hafta buy a new one?
Modified by ahrpr at 8:58 PM 8/21/2005
Old Aug 21, 2005 | 08:55 PM
bump for my o2 sensor
prelude_93vtec
Apr 11, 2007 05:09 PM
LukieLuc
Mar 24, 2007 09:14 PM
Purple94EX
31
Jul 13, 2006 04:43 AM
Fliplm0de
May 9, 2006 08:08 PM
shortlid
Mar 15, 2006 05:04 PM
