Window motor or switch?
Old Aug 27, 2009 | 08:53 AM
Bayhustle81's Avatar
Default Window motor or switch?
(1997 db8 Integra) Well i rolled down the window to go to work and when i got there it wouldn't roll up. i can hear the switch wanting to go down but nothing with the switch coming up. http://images.ibsrv.net/ibsrv/res/sr...ilies/thud.gif. all the other windows work just fine. would it be the switch or the motor and how cam i find out
Thank you Honda tech
Old Aug 27, 2009 | 11:16 AM
eaglewesman's Avatar
Default Re: Window motor or switch?
Not sure about the G3, but on my G2 my passenger window switch didn't work, yet I could move the window with the driver passenger switch. Turns out, the driver switch was bad (not the passenger side one). I figured this out after I replaced the motor and passenger switch... I would try the driver switch first, since it is easiest. It has a greater chance of failing than the actual motor.
Old Aug 27, 2009 | 11:40 AM
w211 ryda's Avatar
I had the same problem when I bought my DB7. Driver side front wouldn’t work so I bought a window regulator thinking that would fix the problem. Installed the regulator and my window still didn't work. So I bought a master power window switch and that fixed everything. If you want, I could check on my spare window regulator which wires you need to test to see if your switch or motor is bad.
Old Aug 31, 2009 | 01:44 AM
yup its the switch!!!
Thanks Guys
Demon R
Mar 15, 2008 05:00 PM
MtbikingKing
May 5, 2006 09:27 PM
spd18
Nov 9, 2003 01:57 PM
spd18
Jun 15, 2003 10:32 PM
dskny
Mar 26, 2003 04:23 PM
