4WS Conversion
Old Jul 25, 2007 | 04:20 AM
  #26
AndyD's Avatar
Default Re: (L-U-R-C-H)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by L-U-R-C-H &raquo;</TD></TR><TR><TD CLASS="quote">Hey Andy, so I take it you have done this conversion? What wire was crossed that you found out was making this problem occur? I feel like I'm really close to finishing this conversion....</TD></TR></TABLE>
I didn't do the conversion on my car. My car was 4WS from the facotry. However, while troubleshooting the random problem of 4WS not working after turning the car off and back on within 15 minutes, I encountered a problem EXACTLY like the one you described.
I am talking about crossing the wires that connect to the 4WS ECU. I can try to take a pic of what I am talking about. Things are kind of crazy for me right no though.
Hope this helps.
Andy
Old Jul 25, 2007 | 06:42 AM
  #27
RobbieDB's Avatar
3rd gen <u>ALL MECHANICAL</u> 4WS FTW.
That electronic crap needs to die.
Old Jul 25, 2007 | 06:46 AM
  #28
L-U-R-C-H's Avatar
Default Re: (AndyD)
How did you accidentally cross any wires though... The two main plugs that go into the 4WS ECU can only go in one way. Did you cut and splice any of the wires yourself or something?
Old Jul 27, 2007 | 06:26 AM
  #29
L-U-R-C-H's Avatar
AndyD, can you please go into more detail about what happened with your situation so that I might be able to figure my problem out?
Thanks!
Old Jul 27, 2007 | 08:23 AM
  #30
sean1121's Avatar
I was thinking he might be referring to the 4 wires that go to the rear actuator but they are keyed to the 4ws control unit.
Old Jul 27, 2007 | 09:47 AM
  #31
preludestud11's Avatar
Default Re: (sean1121)
dang you really need to figure this out. Have you tried the neutral setting that kevin was talking about?
Old Jul 27, 2007 | 11:16 AM
  #32
sean1121's Avatar
Default Re: (preludestud11)
I've still got his 4ws control unit, about to ship it back since it tested fine.
Old Jul 27, 2007 | 12:02 PM
  #33
ohh ok.
Old Jul 27, 2007 | 03:49 PM
  #34
L-U-R-C-H's Avatar
Yeah, there's no way to cross the 4 wires that go to the actuator or ECU because they're shaped a certain way so that that cannot happen....
Old Sep 8, 2007 | 04:15 PM
  #35
pdx88lude's Avatar
Default Re: 4WS Conversion (L-U-R-C-H)
Hmmmm seems like you guys all might need some of this ....http://www.prelude3g.com/
Old Sep 8, 2007 | 06:26 PM
  #36
mgags7's Avatar
Default Re: (leroy06)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by leroy06 &raquo;</TD></TR><TR><TD CLASS="quote">i have 4ws but its not workin!!!!!</TD></TR></TABLE>
thanks for your great input leroy lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD &raquo;</TD></TR><TR><TD CLASS="quote">
Hope this helps.
Andy</TD></TR></TABLE>
I'm trying to figure out how wires get crossed when they're pinned into connectors....
Old Sep 10, 2007 | 09:50 PM
  #37
Altilude's Avatar
Default Re: (mgags7)
haha leroy.
ummm... reading through an additional to the 4ws system manual. I found this...
If power to 4WS control unit was shut down for battery
replacement, 4WS control unit removal, or removal and/or
replacement of No. 43 (10-amp) fuse from dash fuse box, 4WS
control must be reset. To reset 4WS control unit, start
engine and turn steering wheel to right lock then to left
lock.
have you tried such a manouever?
code 10 has to do with the sub steering angle sensor, which means that any of the front sub angle steering sensor, 4ws control unit, or harness connector could be affected.
code 22 has to do with the main steering angle sensor, which mean sthat any of the front sub steering angle sensor, front main steering angle sensor, 4ws control unit, or harness conector could be the problem.
from reading the post, it's obvious you had your 4ws unit tested and probably checked your connections, which leaves the angle sensors. this 4ws additional I have might help you out - it basically goes through how to set up 4ws for the first time (setting the angle sensors with flashes from the control unit), PM me and I can email it to you. it's a ~4meg pdf.
cheers and good luck.
Old Sep 11, 2007 | 07:35 AM
  #38
Default Re: (Altilude)
I will be converting my 5th gen soon. Trouble shooting the 4ws unit is a PITA, but it is well worth it.
Old Sep 11, 2007 | 09:15 AM
  #39
sean1121's Avatar
5th gen 4ws conversion! Can't wait till we get this started!
Old Sep 11, 2007 | 09:16 AM
  #40
sean1121's Avatar
Default Re: (RobbieDB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RobbieDB &raquo;</TD></TR><TR><TD CLASS="quote">3rd gen <u>ALL MECHANICAL</u> 4WS FTW.
That electronic crap needs to die.</TD></TR></TABLE>
Advantages to both. The 3g system is much simpler and therefor much easier to work on.
Old Sep 11, 2007 | 01:21 PM
  #41
^^ yes, but the electronic system is smarter.
Old Sep 12, 2007 | 04:04 AM
  #42
sean1121's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludestud11 &raquo;</TD></TR><TR><TD CLASS="quote">^^ yes, but the electronic system is smarter.</TD></TR></TABLE>
So smart we couldn't fix your's yet!
Never driven a 3g but the 4g 4ws *should* work better as the car takes speed, turn angle, and other inputs into account.
TREESnoseeds787
Nov 5, 2008 04:15 PM
RenzoDaPlayboi
Oct 17, 2006 11:23 AM
dkrex001
Sep 8, 2006 04:39 PM
fscot
Sep 10, 2005 02:36 AM
menappi
Jan 13, 2004 12:35 AM
