amp questions???
Old Apr 12, 2002 | 11:14 AM
s73's Avatar
s73
New User
Default amp questions???
I am trying to put in a amp for my 97 civic ex.
I have a question about the wiring of the amp......i need to hook up the remote terminal (RMP wire) for the amp. (remember....6 gen civics do not have power antenna) There is a power antenna lead that comes out of my Pioneer headunit......should i hook it up to that? (does that wire get power from the head unit when the radio is on???) or i should just hook it up to some other accessory wire with a switch in the middle (to turn on or off the amp, so i don't have the amp on when the radio is off)
please give me a post if any of you guys know about this topic!.....i really don't know much about car audio stuff!......thanks a lot
Ps.....do any of you guys with 6 gen civics get these nasty buzzing sounds in the rear when you play songs with a lot of bass?......anyways to fix it???......i know its coming from the deck in the rear (u know......the part that covers the third brake light).....i had new 6X9s in there.....the speakers are installed right......i think is the cheap honda plastic deck......
Old Apr 12, 2002 | 11:29 AM
Malachi's Avatar
Default Re: amp questions??? (s73)
yes, run the wire from the antenna lead on the pioneer deck to the amp.
Old Apr 12, 2002 | 11:35 AM
poison's Avatar
all a remote does is another power source from your head unit to the amp. in your pioneer deck there should be a blue wire for the remote wire (which is also used for power antenna). for the "buzz" you are getting, does it sound like your engine running (as in, getting higher pitched when you are revving your motor)??
what kind of buzz is it. alot of times you get a buzz in the rear because of either a bad ground, or the power to where it's going is alot and picks up the engine noise.
Old Apr 12, 2002 | 11:40 AM
Malachi's Avatar
Default Re: amp questions??? (poison)
i think it sounds like he's just talking about the rear deck rattling
Old Apr 13, 2002 | 02:28 PM
s73's Avatar
s73
New User
thanks for all the help guys!!
ya.....it is the rear deck......it seems like part of the rear deck is really "floppy".....one of my other friends also have the same problem......i think its just one of those things that honda screwed up on.........
just wondering if anyone else have the same problems in their civics.......and what they have done to fix it
btw.....its a 6 gen 2door
Old Apr 13, 2002 | 07:54 PM
miahmouse's Avatar
Rear deck rattles im my car too...
solution: Turn up the radio.....
Old Apr 14, 2002 | 09:55 PM
kkim's Avatar
try stuffing (cloth, foam, etc.) something between the panel and the steel supports underneath. you may get lucky and find out where the rattle is coming from. after you find the rattle, be ingenious and find other materials that you can stuff in there for a more professional install. good luck.
Old Apr 14, 2002 | 11:00 PM
poison's Avatar
Default Re: amp questions??? (miahmouse)
this is true, always works
Old Apr 15, 2002 | 07:36 AM
s73's Avatar
s73
New User
Default Re: amp questions??? (kkim)
(kkim)
thanks i will try that out......
(miahmouse)
i can't just turn up that radio!!........the ratte is coming from the rear deck because my speakers is causing the rattle!....(only when my system hit some low bass notes).......i guess i just need to stuff all kinds of junk i can find under the rear deck....
Old Apr 18, 2002 | 12:51 PM
Rainmaker's Avatar
Depending on what model Pinoneer deck you have, you might not want to use the power natenna remote. On higher models, the stereo is smart enough to lower the antenna when you switch to CD. If your amp is connected to the antenna remote, and the stereo has this feature, then the amp will shut off when you switch to CD. Of course, if the stereo has that feature, then it definitely also has an amp remote lead, which is energized at all times when the unit is on. Moral of the story: use the AMP REMOTE LEAD intead of the ANTENNA REMOTE LEAD, if your head unit is equipped with both.
Rainmaker.
8YourV8
Audio / Security / Video
13
Dec 11, 2010 09:50 AM
SIC_jdm_da9
Apr 23, 2007 10:33 AM
97civicB18C
15
Mar 5, 2007 10:19 AM
DownBoyDown
May 15, 2003 10:12 AM
haloseven
Mar 12, 2002 07:21 PM
