1st gear problem?
Old 11-05-2004, 09:40 PM
h22a3prelude's Avatar
Default 1st gear problem?
I recently did a swap and for some reason it seams to be kind of hard to get into 1st gear now sometimes. If I roll forward or backwards and inch or two it will go in fine. This only happens occasionally.
Anyone else ever deal with this problem? Is there anything I can do to stop it from happening?
Thanks for your help.
Old 11-05-2004, 09:56 PM
mathews's Avatar
sorry i cant help. maybe try switching to synchromesh for a quick fix.
Old 11-05-2004, 11:08 PM
esca's Avatar
Default Re: (prylwd)
same with me too man..
my solution might be kind of annoying but all i do is pump the clutch once or twice.. maybe shift into second and throw it into first.. and try from there
Old 11-06-2004, 04:45 AM
mgags7's Avatar
its a very normal thing, when your not moving, the syncro isnt either, so the gears dont line themselves up....you usually can try going into other gears and then try first again, but this sometimes wont work....if you cant get it in before you start going, push it in as much as it will go and just hold pressure on it as you start to let out the clutch and give gas, it will go in......
Old 11-06-2004, 02:49 PM
h22 civic's Avatar
Default Re: (mgags7)
the syncro hub and slider are prob chewed up
Old 11-07-2004, 08:29 PM
Default Re: (h22 civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22 civic &raquo;</TD></TR><TR><TD CLASS="quote">the syncro hub and slider are prob chewed up</TD></TR></TABLE>
The thing is I drove this car for a year before the swap, using the same tranny with no problems. So that is probably no the case, is it?
BlueStar
07-26-2008 07:14 PM
Villenurve
10-12-2007 09:58 AM
rIceNOodles
01-26-2005 01:01 PM
D15VTEC
03-19-2003 05:17 AM
Jt240
08-23-2002 05:11 PM
Quick Reply: 1st gear problem?
