When do you use stands?
I use mine whenever...
1) The bike is going to be out of commission for a while.
2) I need to remove the wheels.
3) I want to look like a pro-racer in the pits.
Location: spinning DnB till your head explodes,jersey/philly
1 Post
Re: When do you use stands? (Patman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Patman »</TD></TR><TR><TD CLASS="quote">Debating on picking up a pair, could I get away with just a rear or is front pretty important too?</TD></TR></TABLE>
i use my rear stand when i change oil, changing tires, cleaning chain, pretty much anytime im working on bike i like a rear stand. i use my cherry picker for the front just when im changing tires.
Re: When do you use stands? (GraphiteAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GraphiteAccord »</TD></TR><TR><TD CLASS="quote">everyday.
My bike only utilizes the kick stand when it's not home.</TD></TR></TABLE>
Is there any benefit with the stands over the kickstand? I was thinking about getting a pair. I try and only ride my bike 1 or 2 days a week to keep the miles low.
Re: When do you use stands? (95ProjectEJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95ProjectEJ1 »</TD></TR><TR><TD CLASS="quote">
Is there any benefit with the stands over the kickstand? I was thinking about getting a pair. I try and only ride my bike 1 or 2 days a week to keep the miles low. </TD></TR></TABLE>
a bike on two stands has far less chances on falling on it's side.
My Name is Nobody
I also use stands as a daily way to park my bike... it only takes a few extra seconds to put a bike up on the rear stand.
a bike on two stands has far less chances on falling on it's side.</TD></TR></TABLE>
I figured as much. The first day I had my bike and put it on the kickstand I didn't get a warm and fuzzy feeling that it was very secure.
1. oil changes
2. chain maintenance
3. safer than kickstand
definitely worth it..even just a $50 dollar LP rear one will work.
my house has wheels on it
My bike only utilizes the kick stand when it's not home.</TD></TR></TABLE>same here the hayabusa's seem to have a history of falling off the kickstand while parked.
Re: When do you use stands? (ucb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ucb »</TD></TR><TR><TD CLASS="quote">300 wide rear tire should help </TD></TR></TABLE>
same here.... i have the set of T-rex stands for $80 new of ebay, good ****....
I use the stands if:
I don't plan on riding the bike for a while and when I do ANY type of maint on the bike.
Oh yeah, when I had my bike in the back of a Penske moving truck, I had it on the stands
Re: When do you use stands? (MSchu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rdblckSV650S »</TD></TR><TR><TD CLASS="quote">
Is that such a bad thing that I dont ride my bike that often? The commute to work is 30+ miles each way...
IIRC, you're supposed to have the bike on the kickstand to help completely drain the bike. You can put the bike up on a stand after to help keep it level as you add oil.
Re: When do you use stands? (LL2009)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LL2009 »</TD></TR><TR><TD CLASS="quote">
same here.... i have the set of T-rex stands for $80 new of ebay, good ****.... </TD></TR></TABLE>
werd, I got the trex units with the triple tee adapter too
Re: When do you use stands? (AzntaggeR)
I use my rear stand anytime I am working on the bike, or washing/detailing it. If for some reason my bike were going to be parked for a while I would put it up on the stand as well, but I ride daily year-round so an extended downtime is not likely.
