Using Regular Auto Coolant?
Old Oct 21, 2009 | 01:58 PM
jdmdc2boi12's Avatar
Default Using Regular Auto Coolant?
Iknow this sound stupid but curiosity hit me.. anyways can u use regular automobile coolant with water mixture on a motorcycle?
Old Oct 21, 2009 | 02:23 PM
EKhothatch's Avatar
Default Re: Using Regular Auto Coolant?
Yes, you can. Or just straight water. Or any mixture of water with a percentage of coolant. Or water w/ cooling additives.
I wouldn't run 100% coolant though. Any measure of 50/50 or below should be fine.
Old Oct 21, 2009 | 03:13 PM
fatboy01's Avatar
Do not use any car coolant that has silicates in it. It will damage the seals in a bikes motor. I know with hondas a lot of people had problems with their water pumps failing because they used car coolants with silicates.
Read the label first
Old Oct 22, 2009 | 11:03 AM
life sux die's Avatar
RIP 1032
why would you want to? a bottle of water-wetter is like $10 tops. i've flushed my system like 3 times now and am using the same bottle water-wetter i bought over 2 yrs ago.
Old Oct 22, 2009 | 12:43 PM
BiffStroganoffsky's Avatar
True. You are in a semi-moderate climate that doesn't have many days in freezing conditions so you don't need 'anti-freeze'. Distilled water would work fine and transfer heat better than a coolant. Pop for the distilled stuff and not the tap.
Old Oct 24, 2009 | 08:03 AM
EKhothatch's Avatar
I've used tap with no problem. I opt for distilled but if it not around not much you can do.
dth0ng69
18
Jul 19, 2009 09:12 AM
Urugly
Oct 15, 2007 01:45 PM
TurBoXBirD16
11
Mar 20, 2003 01:55 PM
SonicGSR
Jan 1, 2003 12:55 PM
morepoop4u
Dec 16, 2001 03:39 PM
