quick question
Old Oct 13, 2004 | 12:03 PM
DeLiRiOu5's Avatar
Default quick question
how do you guys wash your helmet if the inner lining is not removeable? just use a damp towel and scrub? or is it ok to submerge the entire helmet under water?
Old Oct 13, 2004 | 12:42 PM
Home Skillet's Avatar
Default Re: quick question (DeLiRiOu5)
I've never washed my helmet yet but assuming that all helmets are water proof I think that would be the way to go. But then again, I'm a n00b with bikes and such.
Old Oct 13, 2004 | 01:13 PM
marmaladedad's Avatar
Helmet fresh spray-in.
Old Oct 13, 2004 | 01:15 PM
DeLiRiOu5's Avatar
Default Re: (marmaladeboy)
i used that stuff from motorex. as i rinsed/rubbed off the spray stuff the water was brown so i ended up just giving it a bath and used tons of soap. hopefully it dries okay...
Old Oct 13, 2004 | 02:25 PM
big pete's Avatar
Default Re: (DeLiRiOu5)
I took my Arai Quantum/f in the shower. Put some soap in, rub it around, and rinse with warm/cold water. Towel/napkin dry as much as you can and let it air dry for around a day or two.
Old Oct 13, 2004 | 04:03 PM
If you do decide to rinse/soak the helmet, let it air dry normally (ie, don't leave the helmet upside down). Don't know why, but every helmet-care manual I've read says this.
Old Oct 13, 2004 | 04:11 PM
DeLiRiOu5's Avatar
a little too late for that.... i put both helmets upside down for about 3 hours. and i just used a hair dryer for about 10 minutes on each one. neither of them are completely dry though. i'll just let it sit for another couple hours and hope all is well.
Old Oct 13, 2004 | 07:40 PM
knuttsachel's Avatar
I always use febrez or lysol. My head has not itched yet!
RaceMyGhost
Lighting
Dec 22, 2007 01:52 PM
werksberg
Welding / Fabrication
Feb 15, 2006 11:24 AM
granturismonut2
Jan 28, 2006 12:50 PM
blmracing
Dec 17, 2004 05:56 AM
Castor
Oct 18, 2004 07:30 PM
