Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Torquing Crank Bolt
Old 02-21-2017, 12:59 AM
Artbuc's Avatar
Default Torquing Crank Bolt
Re 2010 MDX
Service Manual says 47 ft-lbs plus 60 degrees. Also says do not use impact. What does this mean? I assume Honda means do not use impact wrench alone because you would not know final torque. However, if you torque to 47 ft-lbs and then use impact to get another 60 degrees, wouldn't that be ok? IOW, the crank bolt does know or care if you rotated 60 degrees with a wrench or impact, right? Thanks.
PS not sure why I worried about this since I have not been able to break it loose, lol.
skinner17
Honda Civic (2001 - 2005)
01-10-2014 06:15 AM
alfred
07-18-2009 02:42 PM
85vdub
09-29-2005 04:51 AM
JeffS
02-28-2002 09:49 AM
Quick Reply: Torquing Crank Bolt
