Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
It was the Spark Plugs!
Old 03-23-2012, 06:46 PM
BanzaiBeast's Avatar
Default It was the Spark Plugs!
The car runs great now, just by changing the spark plugs! I had heard before that NGK plugs were the way to go with Hondas, I've had 10. Bosch Platinum plugs have acted good in my cars until now.
Car: 2003 Odyssey w/184,000 miles
Problem: Sluggish and coughs under hard acceleration
Signs: CEL comes on and code reader says intermittant misfire
Likely Causes: Bad Coil Pack, EGR blocked, or PCM fried
Disconnecting one coil pack at a time, they all seemed to make the engine run worse.
Pulled EGR and cleaned it, it didn't look clogged.
Pulled one plug, the gap looked a little big - within gap range.
"Let's replace the plugs, it's probably about time anyway!"
Changed them with NGK plugs and it was like driving a different car. Took it back to AutoZone where my buddy cancelled the warning code light and he said, "Yeah, you got to use NGKs in Hondas!"
I have had cars run 100% better on plugs that look ten times worse. Don't be deceived by how they look.
Old 04-07-2012, 01:43 PM
www.megameet.org's Avatar
Default Re: It was the Spark Plugs!
Yep
Old 04-20-2012, 03:23 PM
kchungb17a's Avatar
I've encountered this problem so many times at the dealership. Nobody believes me when I say that aftermarket plugs can cause running problems. Aftermarket wires and distributors too. But when I change them out and put OEM NGK's in everything is fine again. Bosch is the WORST!
Bruce Banner
09-25-2009 02:46 PM
StockAccord
12
08-24-2009 09:53 AM
jdmturbo1127
05-21-2007 12:29 PM
HondaCVT
Honda Fit
06-28-2006 11:18 AM
Rhythmsnewsn
04-20-2006 08:36 PM
Quick Reply: It was the Spark Plugs!
