Code 20- Electrical Load Detector?
Old Mar 1, 2007 | 03:38 PM
building boost's Avatar
Default Code 20- Electrical Load Detector?
This is drivin me crazy. I am getting no spark, I even tried a friend's working dizzy. All grounds are perfect. I am getting cel code 20, electrical load detector. Would this cel code stop me from getting spark? The ELD itself is getting 4.45 V.
Old Mar 2, 2007 | 11:49 AM
Old Mar 2, 2007 | 12:49 PM
JasonST's Avatar
Default Re: (building boost)
The Eld itself shouldn't prevent u from starting ur car. The culprit lies elsewhere. If u already tried another dizzy, try a diff ecu/spark plugs and spark plug wires. Also u sure ur not getting spark? What method are u using to see if u have spark?
Old Mar 2, 2007 | 12:54 PM
in10ceCiviC's Avatar
Default Re: (JasonST)
i just put in a chipped p28 and my car was flashing a code 20 too................
car runs fine.....so its the computer ? what do i do ? .....never did my car flash code 20 until i put the chipped ecu in the car...
Old Mar 2, 2007 | 01:16 PM
SuzukaBlueAP2's Avatar
Default Re: Code 20- Electrical Load Detector? (building boost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by building boost &raquo;</TD></TR><TR><TD CLASS="quote">This is drivin me crazy. I am getting no spark, I even tried a friend's working dizzy. All grounds are perfect. I am getting cel code 20, electrical load detector. Would this cel code stop me from getting spark? The ELD itself is getting 4.45 V.</TD></TR></TABLE>
That code will not prevent your car from starting and running.
How did you get that Voltage for the ELD?
It is a unit that is built into the fuse box.
If you are not getting spark, and you already replaced the cap, sounds like the ignitor is bad.
Old Mar 2, 2007 | 01:21 PM
JasonST's Avatar
Default Re: Code 20- Electrical Load Detector? (SuzukaBlueAP2)
yeah sounds like the ignitor or ignition coil is bad but he says he's tried his friend's working dizzy... Was it the same obd dizzy u used?
Old Mar 2, 2007 | 06:48 PM
turned out to be an exposed wire from my hid's touching the chassis. i can't believe how stupid this was.
j_moua
Nov 22, 2019 11:09 AM
em12nv
34
Jan 21, 2008 02:26 PM
0bd1_Kanobe
Dec 11, 2006 06:41 PM
jpangeles
Oct 13, 2004 06:57 PM
Shakes
Apr 18, 2004 07:20 AM
