Honda Fit Honda Fit (Jazz)
Fir Misfires on start up
Old 10-10-2016, 09:55 AM
Trina Martinez's Avatar
Default Fir Misfires on start up
This Fit has us going nuts, it has new spark plugs and packs, the car misfires only on start up once it is warm, the vehicle runs fine with no issues..Did a compression test I am thinking its to low but its showing 115 across the board....Not sure what is normal compression on a fit with 164k...We almost fed up and ready to drop a pull a part engine in it but, it would be nice to find the issue with this car. Never had a fit stump us like this b4...any ideas before we just write the engine off?
Old 10-11-2016, 11:34 PM
claymore's Avatar
Default Re: Fir Misfires on start up
Adjust the valve clearances now.
Old 10-27-2016, 07:58 PM
ky335i's Avatar
you should always do a dry and wet compression test to see if cylinders have compression. The wet test you take out the spark plugs and squirt oil in it.but before doing this do a dry test and record your numbers. after do a wet test, if results are a major difference between wet and dry you know that you have a bad compression or most likely bad piston rings.
SilkyJohnson
13
02-15-2011 05:54 PM
Junkie
03-22-2008 12:21 PM
InLimbo87
11-04-2004 05:05 PM
J-g-D-s-M-r
09-29-2003 02:32 AM
smslude
02-25-2003 10:40 AM
Quick Reply: Fir Misfires on start up
