05 crv Driver rear window won't go back up.
Like the title says, rear drivers side window won't go back up. Will go down, all other windows work fine. Tried new switches with no change. There is no click from the relay when trying to go up. Tested wires, both wires to the motor will light up +12v when the switch is activated to go up. Down is normal one wire +12v and the other ground. Jumping the harness I can get the window to go up without issue so the motor and regulator are fine. I pulled the wiring out of both door grommets as much as I could and didn't see any breaks. Jiggling and pulling on all the wires I could get to doesn't change anything.
At the rear switch I get +12v like I said at both motor wires but also the brown wire.
I am assuming it is a wire break (shorted and bridged) somewhere but am out of places to look.
Also on the drivers front door grommet, I can't seem to get the grommet out of either the door or pillar enough to get the connector unplugged so I can get a real good look at the whole harness there. Whats the trick for that one?
Yahimbo
10-10-2017 12:52 PM
rhdins
10-19-2012 02:38 PM
Lou_EM1
01-09-2012 10:16 AM
civicseth
12-14-2005 10:18 PM
