WRITE UP: How to convert your fuel lines and ugly filter to Stainless -6AN hoses
Old 01-09-2011, 01:23 AM
  #676
kirkland's Avatar
Default Re: WRITE UP: How to convert your fuel lines and ugly filter to Stainless -6AN hoses
Love how it gets rid of that thing hanging from the firewall.
Old 01-13-2011, 07:29 PM
  #677
Charlie Moua's Avatar
so how do you remove the stock fuel rail inlet fitting?
is it threaded on the other side or do I just pull it out with force?
Old 01-14-2011, 12:00 AM
  #678
MadLorGLK's Avatar
awesome tnx
Old 01-15-2011, 05:25 PM
  #679
traction issuez's Avatar
Threaded, u can try double nutting it to remove it but much easier if u have someone with a torch to heat up the fuel rail but make sure there is no fuel in the rail for ovious reasons to ease of removal.
It was definite a bitch a half to remove it, so have fun
Old 01-16-2011, 10:13 AM
  #680
thegatekeeper14's Avatar
theres always this option, they have a banjo style as well. id check with them. its a great design and works well.
http://www.mnhondas.com/showthread.php?t=11594
Old 02-27-2011, 12:26 PM
  #681
coupedragracing's Avatar
quick question how do these work.. Swivel-Seal Straight Hose End. does it just slide over hose and no leaks. or what.. is there clamp hiding like the Russell Tube Seal Hose Ends? thanks Jose
Old 02-27-2011, 09:47 PM
  #682
spAdam's Avatar
If assembled properly, they seal themselves quite well. No janky hose clamps involved. Watch the tech videos on anplumbing.com and you'll see how it works.
Old 03-05-2011, 05:27 AM
  #683
thedb63's Avatar
your not going to use it again so just vicegrip the the threads and lefty loosey!!
Old 08-03-2011, 03:33 PM
  #684
Who the fack changed my title?!
sh!ft's Avatar
old thread back for the newbies lol.
so, did any one ever answer the question of using the stock flare nut on the oem line coming out of the fire wall to a braided line? instead of just cutting and reflaring??
Old 09-01-2011, 03:12 PM
  #685
sh!ft's Avatar
still waiting....
Old 09-02-2011, 11:39 AM
  #686
nineohnine's Avatar
yes you can i have done it.
use this part
http://www.summitracing.com/parts/EAR-9894DBHERL/
if your stock fitting has a small unthreaded portion on the end you have to carefully cut it off with a dremel. and make it as strait as possible.
its not that hard it took me a while to get the ***** to cut the unthreaded portion off...
but cutting and reflaring isnt hard either and i actually ended up doing that anyhow..
but the stock fitting worked for me for over a year untill i decided to clean it up more and use bulkhead fittings.
Old 09-02-2011, 11:47 AM
  #687
sh!ft's Avatar
so you attach the female end onto the hard line and attach the male end to the 6an fitting after you cut the spaced out portion of the nut?
Old 09-02-2011, 11:52 AM
  #688
nineohnine's Avatar
yes sir. be very careful not to cut the hardline when you cut that spaced portion off(like me lol) otherwise you are going to have to reflare it anyway. and make sure to use teflon paste on the fitting as well.. then just tighten that earls fitting onto the stock fitting then the an fitting onto the earls fitting... instant an conversion lol
page 4 also has an explanation of this and alos a picture of the fitting without the threaded portion that is in question
Old 09-02-2011, 12:14 PM
  #689
sh!ft's Avatar
thank GOD, i did not want to have to go to the extent of cutting and what not.
Old 09-02-2011, 07:43 PM
  #690
nineohnine's Avatar
its actually not that bad using the right tools... i re-routed my fuel lines using 5/8 aluminum hard line so both exit the firewall where the feed line exits stock.. surprisingly it wasn't too hard.. just time consuming...
Old 02-20-2012, 08:33 PM
  #691
rhdjdm86's Avatar
does any one knw how to contact wesv iv got alot problems im runing into . i need this project done thnx guys
Old 02-21-2012, 04:23 PM
  #692
rhdjdm86's Avatar
i got alot of questions need to help
Old 02-22-2012, 05:19 AM
  #693
spAdam's Avatar
What questions do you have? I'm sure someone here could help.
Old 02-22-2012, 08:54 AM
  #694
TheSauceSpot's Avatar
Im sorry to inform but, Wes V passed on a few years back, RIP to a great enthusiast.
While this thread is back to life.. I have a question. anyone with experience using the Jiffy Tite quick connect fittings?
Old 02-22-2012, 07:20 PM
  #695
rhdjdm86's Avatar
hey yea ohhh mannnnnnn that really sux im trying to find out how im supose to get a fitting on the that braket. im thinkn how to do this i got all my fittings i just now need to knw how to get my an fittings on the braket,
Old 02-25-2012, 07:55 PM
  #696
rhdjdm86's Avatar
yea so do i weld on the line ???
Old 02-26-2012, 09:03 AM
  #697
spAdam's Avatar
Show us a picture of what you're talking about, your description is a little vague. You shouldn't need to weld anything.
Old 03-10-2012, 01:31 PM
  #698
sh!ft's Avatar
Originally Posted by thedb63
got the inline fuel filter and fittings just in time to pull the engine!!!
did you have to re-flare the hard line when you installed this????
Old 03-10-2012, 01:55 PM
  #699
spAdam's Avatar
No. That's a compression fitting.
Old 03-12-2012, 06:38 AM
  #700
jdmkid1989's Avatar
im soooo confused on this! So i cut off the fuel line that meets with the filter, but where exactly do i cut it? sorry for the newb question, but im really interested in this
Quick Reply: WRITE UP: How to convert your fuel lines and ugly filter to Stainless -6AN hoses
