Whats wrong with my EF9!!!!????
okay sooo i got 1988 Ef 4speed tranny
and i was driving it not to long ago.
everything was smooth and normal
then all of a sudden
my car stop moving!!!!!!!!
started smoking
my car still starts up and go into gear but it wont move.
it dont wanna grab it putter like it wants to stall.
so what can be the problem?
im guessing its either my Tranny or Clutch
but im not sure thats why im asking on here
Thanks.
started smoking
Thanks.
EFB055
Re: Whats wrong with my EF9!!!!????
okay sooo i got 1988 Ef9 4speed tranny
started smoking
Thanks.
started smoking
Thanks.
Is the smoke coming from the engine bay? Is there any drive at all? Does it start and idle clean?
i too am having this prob.but not the smoke i give it gas and it bogs like it wants to shut off, starts right up fine idle but gos no where 5mph
Keyboard Humorist
My bets on that as well.
Disconnect the exhaust before the car and see if it runs better.
It will be LOUD so don't freak out. Just test to see if you get your power back.
If you do, then completely remove the cat and shove a corwbar or broomstick through the cat so you can drive it around a little quieter.
Take that thing in and get a new cat... and a tune up too.
Cats fail because your engine isn't running right.
you car is having an identity crisis because you keep calling it an ef9, when its most likely an ED9?
but i would bet on the cat being bad as well
my uncle looked at it and said i spun a bearing........thats all bad if i did.
EFB055
EFB055
It wont rev in neutral either? If you can rev it in neutral then it's a clutch or transmission problem. If you can't, then I don't know. If it was an engine problem, or a blocked cat then it would smoke irregardless of whether you were in neutral or not.
