Valve noise?
Valve noise?
I have a slight ticking from my engine, which I assumed was valve noise.
A buddy of mine told me to tighten down the little flat-head screws that are on the springs in case they are loose. Would this help?
I already checked oil pressure, it's fine. Someone also told me that Honda valvetrains are just plain noisy. Is that true?
Re: Valve noise? (Tippyman)
First off, make sure its not the fuel injectors.
Second, you can't just tighten them down, you have to check valve lash . Here you go.
http://www.c-speedracing.com/h...t.php
Location: Land of the free, whoever told you that is your enemy
Re: Valve noise? (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx »</TD></TR><TR><TD CLASS="quote">First off, make sure its not the fuel injectors.
http://www.c-speedracing.com/h...t.php</TD></TR></TABLE>
Good info. I also recomend getting the tool from snap on to adjust your valves with. It makes it 100 times easier. If your car is vtec, it could be your LMAs aswell, expecially if you have big cams. Start by adjusting the valves and then go from there.
Re: Valve noise? (CRXBart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXBart »</TD></TR><TR><TD CLASS="quote">
Good info. I also recomend getting the tool from snap on to adjust your valves with. It makes it 100 times easier. If your car is vtec, it could be your LMAs aswell, expecially if you have big cams. Start by adjusting the valves and then go from there. </TD></TR></TABLE>
(LMA's get pretty freakin loud too)
Anyway, do not just tighten them with a screwdriver, I repeat DO NOT
Re: (Speed--Freak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speed--Freak »</TD></TR><TR><TD CLASS="quote">Hey BMWBart, what tool?</TD></TR></TABLE>
http://buy1.snapon.com/catalog...talog
It's might not be your valves. I have the same noise but mines very loud. We checked for valve lash but all were very very tight because of my cams. It's my injectors. They are extremely loud. Put a screw driver ontop of were each valve position and listen then put it on the injectors. You might find out it's just your injectors. Wish you the best of Luck.
I also recomend getting the tool from snap on to adjust your valves with. It makes it 100 times easier. </TD></TR></TABLE>
Actually amazon sells the tool for 12 bucks, yes 12 bucks. Great tool.
http://www.amazon.com/gp/produ...28013
Re: (Autoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autoworks »</TD></TR><TR><TD CLASS="quote">
http://buy1.snapon.com/catalog...talog</TD></TR></TABLE>
No either of these. 12 mm for LS/CRV, and 10mm fits everything I've ever done so far. B-series vtec, D series, and I'll get back to you on the k!
http://buy1.snapon.com/catalog...store
Basicly they are the same as that amazon tool. I got hosed. Buy the one posted above from amazon. Unless you want to be a baller and gett he overpriced snap on crap.
Re: (CRXBart)
Unless you want to be a baller and gett he overpriced snap on crap.</TD></TR></TABLE>
you baller
you baller
Re: (90blackcrx)
you baller</TD></TR></TABLE>
No I was just unaware of the cheaper version. That soo looks like snap on just buys those things, add their little handle and multiplys the price....
Re: (CRXBart)
No I was just unaware of the cheaper version. That soo looks like snap on just buys those things, add their little handle and multiplys the price....</TD></TR></TABLE>
Was kidding, but yeah its pretty much the same deal. Works great.
Re: (90blackcrx)
when i swapped in the sk2s2s my valvetrain got really loud.everything is in spec and im running stock LMA (i got an sir2 head)..but i kinda like it now,sounds mean at idle
Re: (CRXBart)
Basicly they are the same as that amazon tool. I got hosed. Buy the one posted above from amazon. Unless you want to be a baller and gett he overpriced snap on crap.</TD></TR></TABLE>
You callin' me a baller, cause I have those tools from SNAP-ON why just for that I am going to make your K disappear magically, just kiddin' I hope you get better soon being sick in the summer is the pits.
Later, see yah in Sept.
Re: Valve noise? (Deo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deo »</TD></TR><TR><TD CLASS="quote">How do you go about quieting down fuel injectors?</TD></TR></TABLE>
You know those spoon reservoir covers, I betcha they make little injector socks too to make them quieter for people that are annoyed by their injectors, lol
Just playin,
Have a great day.
Caleb
Just playin,
Have a great day.
Caleb
Re: (Caleb V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Caleb V »</TD></TR><TR><TD CLASS="quote">You callin' me a baller, cause I have those tools from SNAP-ON why just for that I am going to make your K disappear magically, just kiddin' I hope you get better soon being sick in the summer is the pits.
Later, see yah in Sept.</TD></TR></TABLE>
I feel pretty good this morning. BTW I have the baller snap on tool aswell.
Re: (CRXBart)
http://www.amazon.com/gp/produ...=UTF8
what about this one anyone use it, or is the other one better?
Re: (big22)
Go with the one that doesn't require a wrench (I.E. completely integrated). The torque specs on the jam nuts aren't very high (slightly over hand tight).
http://www.amazon.com/gp/produ...28013</TD></TR></TABLE>
Bringing this back up, this tool will not work on b16 or vtec heads in that case. Its made for a 12mm and the b vtec heads are 10mm. Bart its your fault, I emailed amazon and they stated this.
Bringing this back up, this tool will not work on b16 or vtec heads in that case. Its made for a 12mm and the b vtec heads are 10mm. Bart its your fault, I emailed amazon and they stated this.</TD></TR></TABLE>
Woah, back from the dea, but good info.
