vacuum lines HF>SI ????
Old 05-30-2007, 11:39 AM
CCCP-ef's Avatar
Default vacuum lines HF>SI ????
dose any one know the proper way to redo the vacuum lines......i have a 89 HF and have a 91 IM
Old 05-30-2007, 07:12 PM
CCCP-ef's Avatar
Default Re: vacuum lines HF>SI ???? (CCCP-ef)
dose anybody know?
Old 05-30-2007, 07:14 PM
DenzComp's Avatar
What do you mean by "redo" ?
Old 05-30-2007, 07:25 PM
crazykamper's Avatar
he is askin i think how to run the vacuum canisters that are on the firewall to the intake manifold, like what line goes where.... help a fellow ef'er out...bump
Old 05-30-2007, 10:12 PM
doublethink's Avatar
good question, i dont know.
bump for you.
Old 05-31-2007, 04:47 AM
jlicrx's Avatar
here are vacuum lines in the box on the firewall for HF - you will only need numbers 7, 12 & 21
this is where they are on the HF engine
this is where they are on the 89-91 Si MPFI engine (88 is a little different)
this is 88
Old 05-31-2007, 07:47 AM
Default Re: vacuum lines HF>SI ???? (jlicrx)
thanks.......but the other question is where is the EGR valve on the SI?
Old 05-31-2007, 12:02 PM
Bob_760's Avatar
Default Re: vacuum lines HF>SI ???? (crazykamper)
only HFs have EGR
Old 05-31-2007, 03:03 PM
CCCP-ef's Avatar
Default Re: vacuum lines HF>SI ???? (Bob_760)
because the SI ecu is giving me code 12
(you see what happens when you let other people use you computer... LOL )
Old 05-31-2007, 08:09 PM
Bob_760's Avatar
Oh right Cali... Is it a Cali emissions manual EX sedan MP6 perhaps? Thats the only PM6 I've ever heard of having EGR. Good luck with that, I'd get a non egr PM6. Other than that I dono.
Old 06-09-2007, 05:29 AM
DenzComp's Avatar
Anyone know if I can use these digrams on my 91 civic? I'm getting ready to go MPFI and want to have all the info. I can get.
Old 06-09-2007, 07:39 AM
jlicrx's Avatar
Default Re: (DenzComp)
vacuum lines will depend on what engine it is - essentially, for the engine to run right (if it doesn't have EGR) you only need vacuum line from throttle body/intake manifold to the MAP sensor and vacuum line from the intake manifold to the fuel pressure regulator
Old 06-13-2007, 11:42 AM
Black Maverick's Avatar
Default Re: (jlicrx)
You wouldnt happen to haev that same diagram for a DX would yoe? I am in the same dilemna
detuned
06-26-2008 01:58 PM
classciv
11
05-09-2007 03:51 PM
rice a roni
12-08-2006 07:55 AM
rice a roni
12-04-2006 01:22 PM
Quick Reply: vacuum lines HF>SI ????
