tranny problem
Old Apr 21, 2010 | 04:55 PM
bradennicely's Avatar
Icon3 tranny problem
i just installed a new clutch now its making some grinding noises and you can hear here metal banging around
i installed the clutch with the flattest side towards the flywheel and used an alignment tool
Old Apr 21, 2010 | 05:28 PM
92 CiviC H.B's Avatar
Default Re: tranny problem
did you drop anything while putting on the starter?.press the clutch in and see if it stops,might be throw out bearing. cable or hydro ?
Old Apr 21, 2010 | 07:53 PM
DAintegraGSR's Avatar
when do you hear this noise... sitting still, driving, while shifting, with clutch in, with clutch out??
Old Apr 22, 2010 | 08:24 AM
cabe tranny
you can hear the grinding while sitting still and it gets worse if you try to put it in gear also grinds a lil and its hard to put it in gear
this is the first clutch i've ever done so im not sure what to expect
also how do you adjust it properly? ive messed with it and still no luck
the car is also on jack stands still but this wouldnt cause the problem would it? its on all 4 so the car is level
Old Apr 22, 2010 | 12:28 PM
92civic_hatch's Avatar
loosen the tension on the clutch cable until you can move your clutch fork up and down about a 1/4 inch or until the cable with the clutch engaged, pedal up, you can move the cable under the adjusting point a finger width back and forth.
Old Apr 23, 2010 | 07:37 AM
do you think this is the only problem? i'll check that as soon as i get out of school
TruenoMike14
Oct 22, 2013 11:36 PM
leono
Oct 14, 2005 09:16 AM
shhh151
Sep 8, 2005 05:42 PM
92TEGGYGSR
Jul 12, 2004 04:56 AM
tegrevboy
Oct 22, 2002 04:11 PM
