tranny has some sort of whining noise.PLEASE HELP!!
well i have recently dropped a b16 in my hatchback. i had it for about a 2 months. yesterday all of a sudden my car started making a noise. it only makes the noise while im in a gear and i only notice it in through 2nd 3rd 4th and 5th gear.
and if i put it in gear and let it deaccelerate the noise goes off and on.and if i accelerate it gets louder till at a certain rpm (maybe like 4000 not sure) it stops until i shift again then it would start making the noise again in that gear. any idea guys? please help! and its a s1 tranny too.
Re: tranny has some sort of whining noise.PLEASE HELP!! (wiZCo)
im not sure i wasnt there when tha person at the show did it.do you think that could be it? i hope so because im low on my right now.
Modified by xlusiveracer at 2:40 PM 2/2/2007
Stouts 'n' Scotch
Re: tranny has some sort of whining noise.PLEASE HELP!! (xlusiveracer)
That ain't good. I'd suggest checking the fluid level, then draining and refilling your trans (if it's even a little low) as a start using Honda MTF. If it still whines after that it could be a bearing problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xlusiveracer »</TD></TR><TR><TD CLASS="quote">final drive/carier bearing</TD></TR></TABLE>
thats from another thread... same whine.
Re: tranny has some sort of whining noise.PLEASE HELP!! (welfarepc)
what would it most like be Main input shaft bearring or final drive/carier bearing?
is it ok fill your tranny fluid from the bolt hole thats on top of the tranny?
I was having the same problem with my d16 tranny, it turned out that i needed input shaft bearing. i just had the tranny rebuild with all new bearings.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xlusiveracer »</TD></TR><TR><TD CLASS="quote">what would it most like be Main input shaft bearring or final drive/carier bearing?</TD></TR></TABLE>
civicb16eg
12
09-03-2007 05:43 AM
