stock mounts for b16 ef swap
I have a mount kit that is for a b series swap for a ef 88-91 civic/crx but i only have the transmission frnt and side mount i need the mount for the engine and rear trans i wanted to know if there was stock mounts that i could use for the engine and rear trans for a b16 cable in a ef
Re: stock mounts for b16 ef swap (axionm1k)
That happened to me once. I used the stock EF rear mount on the crossmember, and used the dog bone mount from the DA and drilled a new hole in it to bolt to the crossmember mount. It looked wierd and was a ***** to install/uninstall, but it saved me from getting a new mount kit and held together until the car was retired.
1 Post
Many of the old mount kits only used 2 new mounts. you can unbolt the stock rear mount and move it over to the other set of holes on the crossmember. You can also use a 90-93 integra rear mount. I have one of those old steel mount kits as well and am using the integra mount filled with window-weld. The 90-93 integra mount is much stiffer and thicker than the stock d series one.
JustEFit
01-01-2013 10:21 PM
