SOHC ZC tranny into D-SERIES block...no problem?
Old Feb 18, 2005 | 09:44 PM
trooper0641's Avatar
Default SOHC ZC tranny into D-SERIES block...no problem?
no problem at all?
Old Feb 18, 2005 | 09:49 PM
90LSpimpin's Avatar
Default Re: SOHC ZC tranny into D-SERIES block...no problem? (trooper0641)
None at all!
All d-series trannys will bolt on to eachother.
Now for my question which pertains to this install. Can anyone tell us whether or not both the sohc Zc and dohc zc use the same tranny? Would u need halfshafts insteaf of normal axles for both trannies? Thanks!
Old Feb 20, 2005 | 07:01 PM
jlicrx's Avatar
Default Re: SOHC ZC tranny into D-SERIES block...no problem? (89SiPimpin)
SOHC ZC and DOHC ZC both use intermediate shaft and 90-93 Integra axles - some SOHC ZC transmissions have same 1-5 gears and final drive as the USDM Si - some have same 1-5 gears as Si and 4.4375 final drive - DOHC ZC has different 1-5 gears and 3.888 final drive - a lot of USDM D-series blocks do not have the tapped holes in the block for mounting the intermediate shaft
Old Feb 20, 2005 | 07:48 PM
Kwicko's Avatar
Default Re: SOHC ZC tranny into D-SERIES block...no problem? (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89SiPimpin &raquo;</TD></TR><TR><TD CLASS="quote">
A little misleading... '86-'87 1st-gen CRX D-series engines don't readily accept most other D-series trannies. I *wish* I could throw a hybrid onto my D15A3...
Mike
Old Feb 20, 2005 | 07:59 PM
90LSpimpin's Avatar
Default Re: SOHC ZC tranny into D-SERIES block...no problem? (Kwicko)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kwicko &raquo;</TD></TR><TR><TD CLASS="quote">
Mike</TD></TR></TABLE>
Bah, those are like the D-series' retarded cousin.
devonb456
May 5, 2010 10:35 PM
xparalandrax
Nov 7, 2007 07:08 PM
B18C1_CRX
Oct 7, 2006 09:43 AM
ninjapanda
Nov 30, 2005 03:16 PM
trooper0641
12
Feb 7, 2005 09:26 PM
