Problem with relay
Old 05-30-2007, 11:29 AM
nihad's Avatar
Default Problem with relay
My relay is flickering dont know why it a good relay i have 3 of them and they do all the same and the ecu light flickers to the engine light flickers to and wont turn off. DOnt know what wrong need help. the main relay. 0063
Old 05-30-2007, 02:34 PM
Andy R's Avatar
Default Re: Problem with relay (nihad)
almost sounds like you may have a line shorted or coming loose between the ecu and relay. a voltage meter can help you out, check for non ground lines to have continuity to your chassis ground.
Old 05-30-2007, 05:31 PM
nihad's Avatar
Default Re: Problem with relay (Andy R)
I figured it out it was the ground on the thermostat i got confused and for got to bolt it up I have had some problems with the wiring on my car i had to pull the whole harness and had to test it out side and then put it back in side. I think it had a bad ground some where Also my left cluster turn signall blew on the cluster gauge on the back. It burned out like a fuse. Not sure it there is any diff with a nippon denso or the one i have a nippon seico.
JShull
61
10-12-2017 09:42 AM
JAlvarez
23
02-09-2011 10:18 AM
Jenkinsal2
Engine Management and Tuning
03-14-2010 11:26 AM
Jenkinsal2
03-13-2010 06:24 PM
anthonylee29
01-29-2006 07:40 PM
Quick Reply: Problem with relay
