power mirror/ harness help
Old Aug 22, 2004 | 11:37 PM
hatchinprogress's Avatar
Default power mirror/ harness help
ok i've been wondering if the stock dx harness is set-up for power mirrors? the reason i ask is because the dx hatch doesnt come with the dash clock but it has the harness for it. so if anyone can tell me if the power mirrors from the 88-91 4dr will fit in a ef? is the harness in the doors? do i need to get a motor for the power( mirror motor) what all is needed???? and i did search
Old Aug 23, 2004 | 06:13 AM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: power mirror/ harness help (hatchinprogress)
well i dont know about hatches or the mirror part but if the harness does suport it then u will have a unused 3 pin connector in the door(s) and like a 10 connector tucked up in the first spot for a switch left of the stereo.
in theory, all u need, if the harness IS there is the power mirrors and the switch.
Old Aug 23, 2004 | 06:52 AM
Default Re: power mirror/ harness help (JC18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JC18 &raquo;</TD></TR><TR><TD CLASS="quote">well i dont know about hatches or the mirror part but if the harness does suport it then u will have a unused 3 pin connector in the door(s) and like a 10 connector tucked up in the first spot for a switch left of the stereo.
in theory, all u need, if the harness IS there is the power mirrors and the switch.</TD></TR></TABLE> yes thats what im thinkin! and if im right and the wires are there i know where to get the mirrors. anyone know if the wires are there???
Old Aug 23, 2004 | 07:28 AM
help, i know im not the 1st who thought of this.. anyone have any info on doin this???
Old Aug 23, 2004 | 08:27 AM
9:30 bump
Old Aug 23, 2004 | 11:34 AM
can anyone help me with this info
Old Aug 23, 2004 | 04:27 PM
DieMaster's Avatar
i dont want u to look stupid or anyrhing here but why dont u look at the harness in your car and see if the plugs are there?
Old Aug 23, 2004 | 06:33 PM
GRAND CIVIC's Avatar
I've installed power mirrors in my 90 si hatch. No your car is not wired for the mirrors but you con get the harness from a foour door EX that has the mirrors. You will need the green plug that goes to the switch. As for the the mirrors you will have to make them, heres how, you will need both mirrors from a 90 EX, then you will have to take the mirrors apart and put all the parts from the powre mirros into your dx mirrors.You will have to use your mirrors because the four door mirrors dont fit right. Its not as hard as it sounds . Let me know how it comes out . Oh yea now you can put a tweeter in the hole that the adjuster used to be in
Old Aug 24, 2004 | 08:25 AM
Default Re: power mirror/ harness help (GRAND CIVIC)
thanks for the info(grand civic) but i think my mirrors were off of a lx and the mirrors fit the car(they sit flush) i just have to drill mounting holes(they wont be seen) i got the plug that was inside the door and i got the plug with the switch, so i think i just got to run the wires? am i right? where would i get the power,and groung from? is it hard to run the wires?
Old Aug 24, 2004 | 06:28 PM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress &raquo;</TD></TR><TR><TD CLASS="quote"> where would i get the power,and groung from? is it hard to run the wires?</TD></TR></TABLE>
no its not hard to run wire and to getr power just get it from the fuse box under the dash and for the ground any bolt thats screwed into the cars body
Old Aug 24, 2004 | 07:10 PM
Default Re: power mirror/ harness help (streetdreams02)
thanks
Old Aug 24, 2004 | 09:28 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetdreams02 &raquo;</TD></TR><TR><TD CLASS="quote">
no its not hard to run wire and to getr power just get it from the fuse box under the dash and for the ground any bolt thats screwed into the cars body</TD></TR></TABLE> yea just get the power frome the fuse box, just make sure its getting power when the key is in the on postion.
Old Aug 26, 2004 | 10:13 AM
done! thanks for the help everyone
crx_si-r
Northern California (Sales)
Apr 25, 2009 07:29 AM
drSquish
Mar 12, 2006 05:36 PM
cagle333
Oct 20, 2004 02:52 PM
hatchinprogress
Audio / Security / Video
Aug 26, 2004 10:12 AM
im done
Aug 9, 2004 02:59 PM
