obd0 to 0bd1 trouble please help
im installing an obd1 gsr motor into a crx si, ive completed the grey plug conversion except for the ecu. im running an obd2 distributor and keep getting a code for the tdc sensor. i took apart the distributor and found a shorted sensor. i replaced it and the car still will not run and still throws the same code. the cars fires for a split second but wont run, ive allready checked the usual things like wiring, timing, firing order and resister box elimination. any help would be apreciated im kind of in a hurry thanks.
Re: obd0 to 0bd1 trouble please help (abitojdm)
maybe try running a obd1 distributor. i know that the obd1 has 9 wires and 2 plugs and obd2 has 8 wires and 1 plug. worth a shot.
marc-111
19
06-20-2006 09:40 PM
cRxAuDio
10-05-2003 01:08 AM
