jacking points?
Old 11-29-2003, 10:28 AM
AaronJ's Avatar
Default jacking points?
I am going to change the oil on my 90 si hatch for the first time tomorrow, i was wondering where i should jack at and where i should put the jack stands.
I would just go ahead and try to figure it out but i read alot of stories of people jacking up their ef's and not being to open their doors and stuff like that. Thanks
Old 11-29-2003, 11:10 AM
RCautoworks's Avatar
Default Re: jacking points? (AaronJ)
Heres a little tip, if you jack the car up from the sides ( rather then the front cross member ) you will be able to get the car up higher when you put it on jack stands. Not pictured in the pics are the frame lift points, you can also jack it up there.
Old 11-29-2003, 11:22 AM
AaronJ's Avatar
can i jack from one of the side points, then put a jackstand in place of it and just do one side, drop it down and do the other?
Old 11-29-2003, 11:33 AM
5lugef's Avatar
Default Re: (AaronJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AaronJ &raquo;</TD></TR><TR><TD CLASS="quote">can i jack from one of the side points, then put a jack-stand in place of it and just do one side, drop it down and do the other?</TD></TR></TABLE>
yes you can. but if you want it to be easier, and you have the convenience of a floor jack, thats the best way.
Old 11-29-2003, 11:35 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AaronJ &raquo;</TD></TR><TR><TD CLASS="quote">can i jack from one of the side points, then put a jackstand in place of it and just do one side, drop it down and do the other?</TD></TR></TABLE>
Yes you can, but if you jack it up from the pinch weld, you usually won't be able to get the jack stand in there.
Old 11-29-2003, 11:57 AM
Default Re: (90blackcrx)
Picture taken from Keith, the picture shows where the frame is to jack it up from there.
FrederickRighteous
17
06-17-2008 12:56 AM
Babakarab
Honda S2000
13
12-05-2007 07:23 AM
moonpieboy
09-24-2005 11:26 PM
STAGE 2
08-04-2004 04:53 PM
TrueZen
01-03-2003 01:13 PM
Quick Reply: jacking points?
