Injector is stuck on ?
I blew a head gasket a week ago and just finished putting everything back together and am working out some problems.
I had the car starting and running ok for a little wile and, I was working on misc things.
And now when turn the key to the second on position the 4th injector stays on always. I must have lost a 1/4 tank in that cylinder It was coming out of the exhaust manifold when I pulled the plugs I must of shot a 3 footer out of the cylinder.
I stuck a noid light in the plug and it is on when the key is on, the others are off.
Does the ecu pulse/ground the injector ? Or send power ?
Should I check for a short to ground, between ecu and injector ? If so I need wiring schematics.
Anyone have any imput ? or anything i should check ?
I am starting to stressssss
Thanks,
Jack
Thanks,
Jack
Chickenjoe757
01-09-2018 03:30 AM
CHRIS29
06-09-2009 04:43 PM
