Injector is stuck on ?
I blew a head gasket a week ago and just finished putting everything back together and am working out some problems.
I had the car starting and running ok for a little wile and, I was working on misc things. And now when turn the key to the second on position the 4th injector stays on always. I must have lost a 1/4 tank in that cylinder https://honda-tech.com/forums/images...es/emsmile.gif It was coming out of the exhaust manifold when I pulled the plugs I must of shot a 3 footer out of the cylinder. I stuck a noid light in the plug and it is on when the key is on, the others are off. Does the ecu pulse/ground the injector ? Or send power ? Should I check for a short to ground, between ecu and injector ? If so I need wiring schematics. Anyone have any imput ? or anything i should check ? I am starting to stressssss https://honda-tech.com/forums/images...es/emsmile.gif Thanks, Jack |
yes, it pulse grounds the injectors. injectors are Aplug in the ECU
-x m d |
Re: (xmd)
check for injector wires in your engine bay that could be possibly grounding out.
