Im stumped =(
Im stumped =(
car is a 90 ef. i just put in a fresh motor.. fully rebuilt.. pulls 165 across compression. so leaks... car will start and i have to keep on the gas to get an idle out of it.. no codes thrown.. but it runs bad.. smokes bad out of exhaust and through my catch can... has fuel. has spark.. and the tach doesnt work now either. any imput is greatly appreciated.. could it have anything to do with grounds? would that stop the tach from working?
Re: Im stumped =(
shouldnt be... i had 2 different distributors on there so far... i started the car on obd1... then i decided to de convert back to obd0.. so ive ruled out distributor, ecu and o2 sensor
Re: Im stumped =(
timing a tooth off?
Broken cam?
i know there is a ground to the thermo housing
can cause similar issues
just more guesses
tell me more about your setup
parts you used ect....
what you have done
Broken cam?
just more guesses
what you have done
Re: Im stumped =(
firing order is correct... its an ls. built bottom end, jg303 cams... timing is on. has 36lbs of fuel pressure, has spark. i have 3 grounds to the motor.. one on tranny. one on the valve cover and one to the intake manifold
Re: Im stumped =(
prior to swapping that engine in there, what engine was in there, did it run correct? if so theres something wrong with the motor u just swapped. u stated its fully rebuilt, but its readying 165 across in compression, im guessing its for boost. try decreasing the fuel pressure on the fpr, down to 30-32
Re: Im stumped =(
i had a gsr in there. and it ran correct..i did do some harness work.. but im 100 sure i didnt flunk anything up. yes its for boost. plus the 30 seconds of runtime probably hasent seated the rings very well yet.. i shouldnt haveto turn down fuel pressure. its a stock pr4 ecu, and my new swap is stock compression.. so it should run jsut as stock
Re: Im stumped =(
did u pour a little oil into the cylinders prior to start up? try to run it for a minute and check the compression again just to make sure everything is alright. i had a similar problem on my d series with freshly new pistons, it was smoking because of the oil i poured in there. and tell us about the tach not working, at all or what?
Re: Im stumped =(
tach doesnt work at all.. no i didnt pour any oil in. its fouled 2 sets of plugs now. im thinking maybe my cams are too much for a stock basemap... they are jg303s.. 417 lift
Re: Im stumped =(
if you have the stock cams, swap them in. before tuning comes swap the aftermarket cams in. those cams have .015" gross lift (right?) and thats probably why the plugs are failing
Re: Im stumped =(
no, u should have ground wires on the wiring harness
that hooks up to the thermostat housing
i have three grounds
one from core support to vc
one from batt-to frame- to tranny
one from wiring harness to thermo housing
got to say, that your tach not working, is saying something
double and triple check your wiring
did you change injectors? or have the right wiring at the resistor box?
or where the box used to be depending on what injectors your using
Re: Im stumped =(
stock injectors.. i have 3 grounds from harness on my thermostat. one to valve cover , one to intake manifold, and one from trans to firewall...
Re: Im stumped =(
try adjusting the dizzy while motor is running? get back to us when you have those cams changed. for the i searched around and for that particular issue, they keep saying on the t housing, clean the terminal where the ground bolts up to, other than that if it keeps happening, problem is in the wiring somewhere
Re: Im stumped =(
count me out
10-09-2008 08:39 PM
dizzyroc88
26
04-06-2007 07:46 PM
turbotime
29
12-10-2006 10:18 PM
